Disable Automatic headlights??
Old May 10, 2005 | 11:04 PM
Sick97SS's Avatar
i just got my 97 camaro SS the other day and i hate the fact that my headlights automatically come on in the dark. i cant turn my lights off for any reason at night. it just buggs me. is there any way to disable this feature???
Old May 11, 2005 | 12:10 AM
Need4Camaro's Avatar
Re: Disable Automatic headlights??
Please do tell if there is, this feature does get annoying at times... It's the reason it ONLY came out in 97...
Old May 11, 2005 | 09:34 AM
psychocabbage's Avatar
My 1995 had it.. and my 2002 has it.. I love it.. there was a write up on how to disable it.. I didnt pay it much attention since I actually prefer not having to touch a **** to turn on a light..
Old May 11, 2005 | 11:56 AM
Sick97SS's Avatar
Ahhh! i cant find it anywhere. it's always good to be able to turn your lights OFF at night, ya know, for stealth driving
Old May 11, 2005 | 11:59 AM
wack0's Avatar
in the 98+ there is a little grey box behind the radio with 2 connectors going to it. I pulled out the big connector and now I can turn my lights on when I want. I dont know if this little box is on the 97's but I assume it would be.
Old May 11, 2005 | 12:23 PM
Jeremy_30th's Avatar
I did it on mine its very easy. If you look on your dash there is a little sensor in the vent thats where you need to get. Take out your radio and you can get to it just twist and it will drop down. Take out the sensor and get a paper clip bend in in a U shape and place it where the light sensor was and you have control over the lights now.
I have no idea why they would put a light switch when you cant even use it
Old May 11, 2005 | 09:12 PM
Chrisz24's Avatar
The switch is so if you need to manually turn on your lights like if your in the rain.
Taking out the sensor was easy, I did it on my 98 after a few months of owning it.
the upper part of the dash pops off, I put a rag over a flat screw driver then pried up the dash over the passenger side airbag, you'll need to push the passenger front A piller to the side and once it's up enough to get your hands in you simply cut the 2 wires going into the light sensor and use a wire nut to connect the 2 on the car together and it's done!
Takes a hole 5 min, only lights that work auto are the DRLs now
Old May 12, 2005 | 04:41 PM
spoonjimlt1's Avatar
Get to it like chrisz24 did but dont cut the wires just pull the sensor out of the clip and do the paper clip thing thats the best way no cuting wires and you can put it back to normal if you want.
Old May 12, 2005 | 11:56 PM
slowpoke96z28's Avatar
easiest way IMO is to pull the radio and disconnect the DRL module. takes only like 5 minutes.
WobblySausage
Oct 7, 2015 10:09 AM
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
