im having 2 problems with my z28...
Old May 20, 2005 | 05:27 PM
Donohue96M6Z28's Avatar
first, wheni turn the wheel, it sounds like sticks are breaking, any idea what that could be?
also, my car doenst start right up, when its been sitting for an hr or more, i have to put the key from on and off a few times and then it will start, what is that the fuel pump? if i try to start it with out doing that, it wont fire up unless i try to start it a couple times, any ideas? thanks i appreciate the help
Old May 20, 2005 | 05:41 PM
myslowcamaro's Avatar
Re: im having 2 problems with my z28...
makes noise only when turning and moving forward? sitting still and turning the wheel?
second part, does it try to crank?, nothing happen at first? can you hear the fuel pump? does all the electrical work when it doesnt start?
Old May 20, 2005 | 05:47 PM
Z06Z28's Avatar
you turn the wheel and sounds like sticks breaking. Woa! Hows your balljoints look?
So does it sound like it's trying to fire up or you just the the starter turning. Can you hear the fuel pump buzzing? So when you turn the key the first time...nothing and no starter juice? Check the starter wires.
Old May 20, 2005 | 06:51 PM
Blownbird355's Avatar
The hard start sounds like your losing pressure when shut down. Could be bed reg or a leak some where. And maybe even pump going out.
Old May 20, 2005 | 07:21 PM
it makes the noises when im driving and when im still and im turning the rims...
when i try to start the car, the pwr will turn on and everything, it cranks but just doesnt start up, until i turn the key off and on a few times.. then it will start
i know im not explaining this well at all, but i dont know the best way to explain it, i appreciate the quick responses
liamcg97
Nov 25, 2019 05:55 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
Rodrigues
Aug 24, 2002 01:46 PM
The Big Show
Aug 12, 2002 04:50 PM
The Big Show
Jul 24, 2002 12:47 PM
