Inspection done on a 00' SS... Your opinions?
Thinking about buying this SS but wanted to get it checked out first, two things came back.. What do you guys think, is this a bad problem? (Car only has 28,500 miles)
MILD REAR END NOISE.
REAR DIFFERENTIAL LEAK STAIN AND REAR END MAKES
NOISE, CHANGES ON ACEL AND DECEL.
Re: Inspection done on a 00' SS... Your opinions?
I'd be wondering how the heck the rearend got to whining in the first place and being that it's pretty hard to mess up a rearend, what did the owner do and did he treat the rest of the car that way too... of course it could just be a defetive rearend, but I've never come across anyone with that. The absence of the additive would only affect LS performance, not the noise of the gears.
And the absense of additive WILL cause noise
I'd be wondering how the heck the rearend got to whining in the first place and being that it's pretty hard to mess up a rearend.
Originally Posted by Blue89Bird
what are you talking about? You obviously havent been around fbodies very long because the stock rear ends are pieces of crap and are VERY VERY easy to break.
...and yes, although your social skills are severely lacking, you probably do have more experience with broken rear ends than me.
Originally Posted by 8BaLL
It doesn't look beat on at all, and this is his wife's car.
Maybe she slammed the clutch with each shift...
His rear isn't broke, it's whining. I guess my f-bodies have all been special b/c I've ran no additive in them and never had any whining. So have many other people.
Well a properly setup, properly working rear end won't whine...so IMO it's certainly not normal, although I wouldn't exactly call it broken either.If you have a standard factory issue posi rear in your 4th gen and never add any additive when you change the gear oil and it doesn't ever make noise, you either have a hearing impairment, or somehow you got one of the few magic rear ends that were blessed by god himself
And on the maturity thing, just fighting fire with fire.
Limited Slip Additive will not cause or diminish gear whine, bearing whine, or gear lash.
It is merely a conditioner for the fiber frictions discs that make up the "limited slip" differential.
If you don't put in the additive, some rear ends will exhibit "wheel hop" on cornering because the discs wont slip properly.
