115MPH Speed Limited LT1 M6??
I have a dumb question. Did any of the M6 LT1's have the 115 speed limiter? I think I remember hearing they were all A4's with non speed rated tires from the factory. Im looking to buy one and I dont think it will be appropriate to go that fast on the test drive. How can I tell? RPO codes? Someone enlighten me!
TIA, Jimi
TIA, Jimi
Re: 115MPH Speed Limited LT1 M6??
Originally Posted by Kataklysm
See if it has Z rated tires. If not then its only 115. I doubt it will be limited though. If it is, it's easy to get rid of. WHen are you going 115 anyways?
Jimi
Originally Posted by nonojoe66
lt1s with the limiter have a 115mph speedo and ones without go up to 150mph
Jimi
I thought the only cars with 115 MPH speedos were those with 2.73s. All M6, and A4s with 3.23s had to have the performance transaxle option that would have required the Z rated tires.
The only year I would question is possibly 93 which offered two 6 speeds, and had some people reporting weirdness in the gear offerings.
The only year I would question is possibly 93 which offered two 6 speeds, and had some people reporting weirdness in the gear offerings.I know - I did it
The literature I read is that the factory speed governor is set to the speed rating of the tires, so if you know the RPO for the z rated tires you could check against the options list on the door
Just get it if its a good deal, fixing the computer is not a problem. Some dealerships will do it if you put on z rated tires and show them... v6ers have gotten dealerships to do it...
and of course there is aftermarket tuning which is WAAAAAAY cheaper for v8 guys and much more common.
honestly don't see it being a point, if its a good point get it.
run it, if it has a limiter, buy a guage cluster, and pcm, for like $120 total, sell our stuff maybe for $50-60
Or jsut get a programmer, or even contact someone that has access to LT1 edit or other lt1 software programs locally and fix it.
I mean I think I know of 2-3 people with lt1 editing software and I don't have an lt1 or know that many people with an lt1.
Imagine my disappointment when I drove my brand new 94 Z28 m6 home, and discovered that it shut down at 105mph. The speedo may go to 115, but the car would not. At any rate that was almost 11 years ago, the limiter went away somewhere around that time, and I will roll 210,000 miles on original drivetrain within the month.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Camaro90RS
Jul 23, 2002 07:57 AM
