Horn problems help
I have a 1997 Z28.
Every time I wash it or it gets wet one of the horns won't work.
Has any body had this problem?
Once it dries both horns work.
What's up with that?
Thanks,
Chris.
Thanks,
Chris.
Re: Horn problems help
Water is not getting into the horns.
The horns are faceing down .
I am stumped.
Like I said I wash my car hood closed and after when I set the alarm.
One horn.
If I hit the horn button one horn.
Thanks,
Chris.
I am stumped.
One horn.
Thanks,
Chris.
Originally Posted by shoebox
Maybe a poor connection at the horn that is getting wet. Unplug it, clean it up and use some bulb grease on it.
I will try it cleaning the connections and put some bulb grease on them.
When I got the car the horn was bad I replaced them both and all was fine for a while.
But it kills only one horn even if I wash the car.
Witch means there is no water getting to the horns them selves.
That's why I'm thinking of something in the wiring harness might have gone wrong in it.
Chris G.
ya my 99 Z is having horn problems... i've jacked with the wires and everything... only the high pitched tone is working. My father has the same problem with his 02 suburban. his low pitch horn wasnt working either, then just randomly one day we tried to use the horn and both sounded off loud and clear! i'm confused too..
fpete1992
Dec 11, 2014 03:51 PM
