96-97 obd 2 motor in 94 ta Q's
Old Oct 15, 2006 | 07:32 PM
snakeatinZ's Avatar
I am building a 96-97 motor to put in my 94 T/a because I dont want to have to deal with the high stall problems people have with a nonvented opti. The motor is going to love spray with a nitrous cam and stall. This will be on a stock bottom end with arp bolt throughout. What do I need to do to the computer to make this work? Do I just get a 96-97 computer or do I need to buy a 96-97 computer and wiring harness? Any info is greatly appriciated.
Thanks,
Steve
Old Oct 15, 2006 | 07:59 PM
sbs's Avatar
sbs
Re: 96-97 obd 2 motor in 94 ta Q's
Thanks,
Steve
All you needed to to if you experienced the high stall problem is to convert to the OBD2 PCM. The opti and the rest of the engine have nothing to do with it.
Since you are using a 96-97 engine, you should just need the PCM. If you were using it with your 94 engine you'd need the PCM and knock sensor.
You're building an engine that "loves spray" with stock pistons?
Old Oct 15, 2006 | 08:36 PM
snakeatinZ's Avatar
So just the computer. How do I go about running a th350? What needs to change to run that tranny?
Stock pistons would not be okay for a 150 - 200 wet shot? Can I get good piston rings? I dont want to have the block bored to turn it in to a 355. What pistons would you run in a 350 ci LT1 if you were doing a budget build up?
Old Oct 15, 2006 | 08:51 PM
blacknsilverz's Avatar
steve i have a stock 97 computer out of my z28
Old Oct 15, 2006 | 09:05 PM
snakeatinZ's Avatar
I love you man!!! Is it for an auto car, or does that matter? I really have no clue when it comes to the computers? How much do you want for it?
Steve
Old Oct 16, 2006 | 04:38 PM
yes steve it is for an auto it was the stock computer out of my car.
Old Oct 16, 2006 | 08:10 PM
snakeatinZ's Avatar
Pmed you!!!
Steve
Ringmaster72
Dec 12, 2017 10:12 PM
HectorM52
Jul 30, 2017 11:46 AM
greenzee28
Mar 26, 2015 09:13 AM
willismoons
Feb 14, 2015 08:42 PM
Queens94z28
Dec 20, 2014 09:11 PM
