What prog do I use to edit.
Old Oct 11, 2006 | 01:12 PM
hektyk's Avatar
I have noticed quite a few editing progs out there for my LT1. The only thing I basically wanna do is just recalibrate my speedo for a higher gear ratio. Whats the easiest way to go about this. I have 273s and I am going up to 373s.
Old Oct 11, 2006 | 04:22 PM
Re: What prog do I use to edit.
You can reprogram your 95 with the OBD-I version of LT1_Edit or TunerCat.
http://www.carputing.com/
http://www.tunercat.com/
If you never plan to do anything other than change the rear axle ratio, you might possibly find a used Hypertech Power Programmer (specifically for a 95) for low $$$. Just make sure the person selling it has returned his PCM to the stock program, or the programmer will not work on your car.
Another alternative would be to send your PCM back MadZ28, to have the gear ratio changed. Doesn't he give you a reduced cost for changes?
n2oTransAmLT1
May 11, 2003 11:24 AM
96z
Mar 24, 2003 11:32 PM
IllusionalTA
Advanced Tech
Mar 12, 2003 02:22 AM
whiteflame
Nov 11, 2002 03:34 PM
97TA-WS6-Con
Sep 14, 2002 11:11 PM
