Quick pcm question
Old Nov 8, 2006 | 10:01 AM
ajlew9428's Avatar
Quick pcm question
whould I have to adjust my pcm if I got 17in 9.5 in zo6 rims on my 94? I have stockers right now.
Old Nov 8, 2006 | 10:42 AM
cjmatt's Avatar
it all depends on the size of the tires you put on, you should get a set of tires that keep the overall same diameter
Old Nov 8, 2006 | 04:49 PM
sbs's Avatar
sbs
As he said, wheel size has nothing to do with it.
Even if the tires are different diameters, you don't _have_ to reprogram. The only thing it will mess up is the speedometer.
Old Nov 9, 2006 | 11:13 AM
VinceTrifecta's Avatar
Some people say that having an uncalibrated speedometer can lead to automatic transmission problems because the programmed shift points and line pressure is based on an assumption about the car that is now not totally correct.
But, the amount of risk is associated with the amount the speedo is off. This is a bigger issue if you're changing gears.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
Jazsun
Dec 29, 2014 12:14 PM
