Tuner Cat Help?? What Table?
Old Oct 18, 2006 | 06:21 PM
DAG's Avatar
DAG
I got a tune from mad and it needs to be Adj a little.. It looks good at WOT but at idle and at cruise its little rich. In what table do i need to lean it up a little at idle and at cruise and do i go up or down with the settings to lean it up???
Old Oct 19, 2006 | 08:28 AM
Sweetred95ta's Avatar
Re: Tuner Cat Help?? What Table?
Well, if you got the tune from Ion, I would imagine it's a closed loop tune. There is nothing you can do at idle and part throttle operation to get it to lean out some. Come to think of it, you might be able to make it idle in open loop, which you would be able to adjust the a/f. That shouldn't necessary with such a 'small' cam. You might have something else wrong if it's running rich. Part throttle a/f changes are possible (limiting your BLM boundaries), but impractical, and you wouldn't want to do it. Are you sure it is running rich? What are your BLMs? How do you know it is fine at WOT?
GREEN3112
Feb 10, 2019 09:19 PM
n2oblkz
Oct 12, 2015 01:53 AM
fift5
11
Oct 1, 2015 10:31 AM
Ks0209
Oct 1, 2015 07:32 AM
Bigtoyz97
Sep 21, 2015 01:44 PM
