IAC follower is too long
Old Nov 26, 2006 | 03:18 PM
Silver's Avatar
OK I trimmed my follower down a bit b/c I hated the car not wanting to idle down quick enough as I came to a stop. Been driving with no problems for a couple years now. A few months ago while working on it, it rolled off the ramps into the light pole at the end of the driveway while in nuetral. It shut off when it hit and I haven't driven it much since until I got it fixed. Well now it's fixed and it's taking way too long to go from abut 1k down to 650 where it belongs when I stop. I've done the reset procedure (slightly depress pedal, crank, let off, run for 5 seconds, switch off for 10 secs) a couple times and it hasn't fixed it, flashed the pcm as well.
Any idea what could have happened? Should I take the IAC off and manually 'reset' it to closed position and reinstall?
lt1matt
Mar 21, 2015 07:35 PM
carl.froehlich
Mar 13, 2015 12:38 AM
grgguy
17
Feb 23, 2015 07:57 PM
pimpss96
Feb 12, 2015 01:28 PM
