Speed density tuning
Old Nov 25, 2006 | 06:45 PM
mdacton's Avatar
I just converted obd2 to obd1 and I have tunercat, The obd1 i have has a stock program in it.
I want to run the car in speed density and run a filter on the tb.
I am new to this and from searching the past few days I know it can be done but there isnt any specific deatail on how to do it....
Also the computer is from an A4 I have M6....is it that big of a deal to just leave it that way? I don't care about the speedo
Old Nov 25, 2006 | 06:50 PM
jay_lt4's Avatar
if you have tunercat it is very easy, load your current bin file into tunercat,
-click tables
-select ecm switch table
-then click in the 4th box down (speed density mode)(x=speed density mode)
save the bin and flash it to your pcm,, remove your maf sensor and fire it up
Old Nov 25, 2006 | 07:00 PM
mdacton's Avatar
o.k. thanks
The more I get into this tuning the more i realize i'm making out to be more complicated than it is
I have been racing and tuning for years just always had to get dirty to did it before, this computer stuff aint too bad
Old Nov 25, 2006 | 07:31 PM
jay_lt4's Avatar
maf mode is much more forgiving to engine mods, in speed density mode the engine will run off of the set vol eff. tables, on a near stock engine they seem to run very good in speed density mode
if you are planning engine mods i would keep the maf sensor, i switched to the larger ls1 truck/corvette style maf sensor and just re-scaled the maf table with numbers from a tunercat obd2 file for the same vehicle type that the maf came from, works perfect on my setup
Old Nov 27, 2006 | 09:16 AM
Sweetred95ta's Avatar
You'll need to make some adjustments (a/f wise) to the VE tables. I run a SD tune.
Old Nov 27, 2006 | 04:28 PM
mdacton's Avatar
how does your car run with the sd?
will the tunercat work with a BIG cam or should I go to a holley 950....the cam is 26x@ 50
Old Nov 27, 2006 | 06:23 PM
SABLT194's Avatar
A Holley 950 system is still usually speed density based fuelling. It in and of itself won't be anymore friendly with a big cam than your GM PCM. If you're drag racing only the 950 could be set up for Alpha-N fueling. That's not too street friendly though. I see you're running a CC306. I ran one just fine with a SD and with an MAFtune, no problem
Steve
Old Nov 27, 2006 | 07:24 PM
mdacton's Avatar
I'm not driving on the street, The reason I ask about the 950 is a few locals run it and have it set up good...some low 10 sec. stock eliminators they all say if I get it they will set it up for me
Old Nov 27, 2006 | 09:19 PM
My car runs pretty good. I'm just running it to see what I think. I'll eventually compare it to a MAF tune. I won't be going back to closed loop though.
Old Dec 2, 2006 | 12:13 PM
mdacton's Avatar
anyone have anytunes I can start out with?
I have searched and most links are dead or the tunes won't work
The ones I have tried run like crap car won't rev over 5k or so... pops real bad and smokes, I know everything in the car is o.k. when i run my tuned pcm it hits 7k no prob. nice and smooth
mdactonjr@aol.com
Old Dec 2, 2006 | 01:46 PM
I would send you mine, but I run a sd tune in open loop. Your car would be pulling lots of fuel because the a/f isn't anywhere near 14.7:1 (it too rich right now). I haven't had time to use my new wideband to get everything dialed in.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Jul 4, 2005 05:00 PM
