Modifed 95 Camaro z28 A4 bin files with 323
Does anyone have a Modifed 95 Camaro z28 A4 bin file with 323 that they can send me. I had a firebird rearend put on my car last week and it had the 323's on it so they tell me im not sure i guess i am going to be screwd till i find out what gears are in it. Any help would be appreciated
5.7 95 Camaro z28
no cat, flowmaster 40
stock motor
5.7 95 Camaro z28
stock motor
you can check your ratio by jacking up the rear end and spinning the tires. i believe that 1 rotation of the tire will equal 3 and a 1/4 turns of the drive shaft. if the shaft goes a full 3 and 1/2 then you have 3.42's. i might have this backwards. you will know as soon as you start spinning the tires. i have a stock .bin and some modded bins. the stock is 3.23 and the mods are 3.23 and 3.42. let me know.
david
david
CamaroHeed
Mar 18, 2020 09:50 PM
NewsBot
Dec 28, 2014 06:20 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
grendal
Apr 15, 2010 05:20 PM
2000silverz28
Jul 20, 2002 06:14 AM
