ECS code 43
Old Nov 4, 2006 | 08:15 AM
jmangler's Avatar
ECS code 43
Anyone get this code before? I tried numerous things to get rid of it and I cant! switched to lt4 knock module and sensor and still get this code? what else could it be.....
1995 Camro LT1
383 8:79 CR
D1SC with FMIC 14lbs
72lbs injectors
Ported polished heads 2.02/1.60
Forged bottom end
TunerCats
Old Nov 4, 2006 | 12:19 PM
jmangler's Avatar
Anybody.....
Old Nov 5, 2006 | 05:14 PM
jmangler's Avatar
I guess nobody has had this issue.....
Old Nov 5, 2006 | 11:48 PM
That code sets when the PCM detects an incorrect voltage on the knock SENSOR circuit. Pull the harness wire off the knock sensor. Check the voltage from the single wire in the harness to the block (key on). Should read 5V. With the harness wire still off the sensor, check the resistance between the single pin on the knock sensor, and the block. Should read 4,500ohm +/-1,000 ohms. Reconnect the harness connector, and probe the voltage from the connector wire to the block, should read in the range of 1.5-3.5V. If any of these tests are outside the range, you have found your problem.
Switching to an LT4 knock SENSOR was a mistake, since the LT4 is essentially the same sensor used in the OBD-II 96/97 LT1 F-Bodys, and has an impedance of 100Kohm, which will definitely set DTC 43, since its outside the range of 3,500-5,500ohms spec'd for the OBD-I knock sensor.
Old Nov 6, 2006 | 02:43 PM
jmangler's Avatar
Thanks for the input! I didnt know that the LT4 sensor was a bad move. Now I can do alittle more trouble shooting. Thanks for your help!
johnsocal
Aug 29, 2002 10:01 AM
Darth Xed
14
Aug 7, 2002 12:21 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
BigDarknFast
Jul 8, 2002 01:37 AM
