New pcm
Old Oct 30, 2006 | 05:38 PM
AXEMAN's Avatar
New pcm
OK so I bought a new pcm at the dealer and the speedometer is about 25 mph high. I bought a cheap laptop and I will recieve it this week. I plan on getting a cable and tunercat so that I can start tuning. How do I correct this? Also does anyone have an aldl cable that they don't need?
Old Oct 30, 2006 | 06:21 PM
2001NBMZ28's Avatar
Never bought a new PCM, but shouldn't the dealer be able to load a tune for your gears?
Old Oct 31, 2006 | 07:05 AM
25 MPG high at what true speed? The error is typically a percentage, and knowing the percentage helps figure out what the source of the error is. Could be the wrong gear ratio, wrong tire diameter, or you have an M6 program in the PCM - although that would cause indicated speed to be more than twice actual speed.
Old Oct 31, 2006 | 04:39 PM
AXEMAN's Avatar
When I get my equipment I will have to check on that. Thanks for your replies.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
