Running out of fuel..but shouldnt...
Old Nov 10, 2006 | 10:12 PM
xxsaint69x's Avatar
having problems supplying enough fuel to my pos.....
here is my fuel system...dual walbros, stock lines, low independance 72lbs injectors, verasfueller, fuel pressure at 39-40 at idle, 44 or so with the vacume off......
car should be makin over 700rwhp.....
With the injectors programed as 70lbs my AFR look liked ****..goin into mid 13s by 6200 rpm, the duty cycle was only 77-80%.....
set the PCM to 66 and it helped a lot...
here is what i am at right now
4800rpm------11.03 AFR
5200rpm------11.75
5600rpm------12.42
6000rpm------12.86
i am at 86% duty cycle at 6200rpms.
my PE table is maxed out from 5200 on at 49.6.
i also changed the Coolant vs aFR at wot table to be at 30 at the opertating temperature.....it didnt seem to help at all .
Why do i need to keep on bumping the injectors down so much?! How come my duty cycle isnt higher..arrr
How come i cant get enough fuel here? what might be holding me back?!
Old Nov 11, 2006 | 01:31 AM
VinceTrifecta's Avatar
It is my understanding that generally fuel injectors do not work reliably above 80% duty cycle. Maybe yours do, I don't know.
However, sounds like you haven't maxxed out your injectors yet - if moving down to 66lbs in the PCM helped it out. It sounds like the PCM isn't calculating the duty cycle correctly. There's a table called Injector Offset Vs. Battery Voltage. The values in this table are going to be correct for stock injectors, but aftermarket injectors, it's sure to be off.
Try populating this table with the values provided from the makers of your fuel injectors and see if setting it back to 70lbs shows improvement.
Good luck
Old Nov 11, 2006 | 09:29 AM
xxsaint69x's Avatar
Good luck
ha...i looked and looked and cant find anything for the bosche 72lb injectors
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
