22 Throttle Position (TP) sensor circuit (signal voltage low)
Old Dec 21, 2006 | 07:21 PM
1970z28's Avatar
can someone tell me what i need to do to fix this on my 94 lt1 street car. it also has a tune from madwolf and he set the idle to 850 but it want idle down to that, stays around 1500 to 2000 rpm. it done this before i sent him the computer and shifts real hard at 1-2 shift @25 mph then 3-4 shift @40 mph and will not go into od. until 55 mph. also thanks to andrew@ akm cables on the repair of a cable from one of there competetors to help get me going.
Old Dec 22, 2006 | 10:34 AM
The code sets when the closed throttle TPS voltage is below 0.20V. You need to test the operation of the TPS, meauring the voltage between the blue wire and the black wire with the throttle closed (0.20-0.90V), rotate the throttle open slowly watching for a smooth voltage increase, and then at full throttle, should read about 4.0V higher than the closed throttle position. Also check to make sure you are getting 5.0V between the gray wire and the black wire at all times (key on).
You need to find out why the voltage is so low at closed throttle. Could be a faulty sensor, may need adjustment ifs its on an aftermarket throttle body.
Old Dec 22, 2006 | 07:15 PM
1970z28's Avatar
thank you will check tomorrow.
Old Dec 23, 2006 | 11:50 AM
1970z28's Avatar
only getting 0.03 v at throttle closed. voltage will not increase when i open the throttle up, between blue and black wire. getting 5.0 v between the gray and black wire. any idea bad sensor it has the stock throttle body
Old Dec 23, 2006 | 03:02 PM
1970z28's Avatar
fixed it, removed the sensor and tried to ohm it out but nothing would happen. went and bought one works perfectly.
HectorM52
Jul 30, 2017 11:46 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
pete53
Dec 9, 2014 07:31 AM
