Scanmaster DTC 63
Old Oct 21, 2006 | 01:22 PM
WejaZ28's Avatar
Scanmaster DTC 63
Scanmaster is reading DTC 63 (Bank 2 (right) Heated Oxygen Sensor (HO2S) Circuit (open circuit).
Car has been idling very rough and running poorly.
Questions:
1) Does (right) refer to the passenger side?
2) Is open circuit refering to a grounded/shorted wire?
Thanks, Weja
Old Oct 21, 2006 | 02:08 PM
01Z's Avatar
01Z
Re: Scanmaster DTC 63
Questions:
Thanks, Weja
I should wait and let someone else answer but here's mine:
Right is passenger side as you suspect.
Open means incomplete or like your light switch when the lights are off.
Old Oct 22, 2006 | 08:53 PM
WejaZ28's Avatar
Thanks for the reply. Since you are the only one to respond, I shall assume that everyone else who read is in agreement. I shall replace the passenger side O2 Sensor as a fix.
Weja
Old Oct 23, 2006 | 12:05 AM
Could also be the power supply (12V) to the heater in the O2 sensor. If "all the goodies" includes headers with O2 sensor extensions, then it could be a faulty extension.
Old Oct 23, 2006 | 08:21 AM
WejaZ28's Avatar
Injuneer,
Your right about that. I made extensions myself to the O2 Sensor. Has been that way for several years, no problems. It is possible one of the wires has been melted. Since car is with my son in Tempe, I have to make assumptions on fix. I am sending him a new extension and O2 Sensor to have installed.
If there are any other possibilites in case this does not fix the problem, let me know.
Kevin
marlar98
Sep 12, 2018 07:18 AM
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
