Limp Mode?
Old Nov 5, 2006 | 10:42 PM
silverstreak_1996's Avatar
Limp Mode?
What is limp mode?
My car hits the rev limiter 1-2 and 2-3 after installing a 3600 stall converter, is this "Limp Mode"?
If so how do I fix it.
1996 camaro, hot cam, hooker headers, MSD 6000, CAI, TB bypass, MSD plug wires and coil, B&M shift kit, 3.73 gear, PCMforless tune.
Old Nov 5, 2006 | 11:42 PM
"limp mode" is the program in the PCM that runs the engine when most of the sensor inputs have been lost. Its just good enough to keep the car running to get it off the road and into a service facility. Doesn't sound like the problem you are having.
Is it possible you have an OBD-I conversion? They will have problems with high stall converters.
Old Nov 6, 2006 | 01:43 PM
97Z-M6's Avatar
as said above if you do have a obd1 conversion, its the stall.
but there is a fix.
Old Nov 6, 2006 | 06:41 PM
Yes, I do have an OBDI conversion.
So, how do I fix it.
Old Nov 6, 2006 | 07:07 PM
Severous01's Avatar
on obd1 cars you need to tune the higher stall converters...anything above about 2800, from what i gather from others experiencing the same thing. they tune for it and it's fine after that.
BTW, limp mode is your cold settings. when the 02 sensors arent warmed up yet and your engine has yet to reach optimunm temperature. this is when you start the car cold until the temp reaches about 160
Old Nov 6, 2006 | 09:08 PM
sbs's Avatar
sbs
Incorrect.
Old Nov 7, 2006 | 06:44 AM
Originally Posted by steve9899
Incorrect.
Yup. I don't know where he gets some of the tech info he posts
Old Nov 7, 2006 | 06:47 AM
MichiganSkip's Avatar
Do you know someone with TunerCat?
Old Nov 7, 2006 | 07:06 AM
97Z-M6's Avatar
yeah me...
send me your bin file, and i will fix it. vincentbergeron@yahoo.com
if i can make a 4400 stall work good on a dailey driver... i can fix yours
Old Nov 7, 2006 | 09:19 PM
Severous01's Avatar
i got my info from my teacher, who's a 30+ year veteran in vehicle maintenance. and he has 15+ years teaching. i talked to him about this last week. but if he's wrong i'll inform him. i'm sure he'll take it well since he just published another book about maintenance on newer cars...
is it possible that "limp home" on GM cars is totally different from any other manufacturer? or just that LTx car's limp home is totally different from every other engine management program? seriously, ... if it is i want to know so i dont sound like a retard to any non=gm fans out there. if not, what's the cold start program called?
Old Nov 7, 2006 | 10:45 PM
Cold start is in "start-up" mode when the engine is being cranked, within a few seconds of the engine actually starting and stabilizing, it switches to "open loop".
For some accurate info on these cars, look at these references:
Corvette Fuel Injection 1982-2001, Charles O. Probst, GM Part # 12497977, ISBN 0-8376-0861-9
Limp home mode is covered in several places. For example - Chapter 2, Engine Control Fundamentals, para. 6.7, Fuel Backup/"Limp Home":
When the computer itself is not operating normally, engine management changes to Fuel Backup, or "limp home" mode. This could be under any of the following circumstances:
-a computer voltage less than 9 volts.
-a cranking voltage less than 9 volts
-missing or non-functioning Programmable Read-Only Memory (PROM)
-if the computer fails to issue Computer Operation Pulses (COP)
When one of these situations occurs, the computer runs on something called the CAL-PAK chip, operating the engine only on inputs from a few sensors: Manifold Absolute Pressure, Throttle Position, Engine Coolant Temperature and RPM
From page 103, continuing the description:
The computer goes into backup ("limp home") mode if the system isn't functioning properly..... You'll get home or to the shop, but without full engine control.
Few people ever experience "limp" mode.
Also review:
Chevrolet Fuel Injection, Ben Watson, ISBN 0-7603-0422-X
Old Nov 8, 2006 | 07:52 AM
What is limp mode?
To answer whether you're experiencing the "limp Home" that is usually associated with "high stall" converters, I'd say you aren't experiencing "limp home" mode. "limp home" when associated with high stall converters is when the car goes from 1st to 3rd and won't go out of 3rd until the car is shut off and started back up. Most have decided that the higher stall rpm and relatively low mph speed confuse the VSS setting and therefor e the computer thinks there is something wrong so it shifts the tranny into 3rd. Some people install 3k+ converters and done't experience "limp home" mode and others do. The latest version of TunerCat for OBD1 has the "fix" in one of the tables. (earlier versions didn't have the setting) So, find someone who can pull your file out of your PCM, make the change and flash it back in and you're all set. but from what you're describing I'd say that's not what I've known "limp home' mode to be. Sounds more like the tranny is slipping or something.
Old Nov 8, 2006 | 08:52 AM
Sweetred95ta's Avatar
I thought the high stall issue was the car wanting to hit the rev limiter before shifts.
Old Nov 8, 2006 | 04:18 PM
Didn't used to be when everyone had the problem 2 or 3 years ago.
Do a search on "high stall"
Old Nov 8, 2006 | 04:49 PM
97Z-M6's Avatar
the stall problem is a very easy fix with programing...just knowing what parameters to set is the catch.
