security light
Old Dec 22, 2006 | 10:10 AM
tet6419's Avatar
security light
I have a 1995 z-28 and the security light in the dash is constantly on.Can anyone tell me what to look for to repair this problem? Thanks in advance for any help
Old Dec 22, 2006 | 10:09 PM
drifter60060's Avatar
Does your car start with this light on? Lock the drivers door and open it with the key (not the remote). That should take care of the problem.
Old Dec 22, 2006 | 10:46 PM
byrons1502's Avatar
does it still start? they can be a little tough to diagnose for a first timer. it should have a vats module and a chip in the key that the vats reads the key resistance when inserted. if it does not like what it sees it may not allow startup. check your key and reply
Old Dec 27, 2006 | 08:22 AM
tet6419's Avatar
The car does start and runs great. have locked the doors and unlocked with the key and the light is still on.the remote will open the hatch however the doors will not unlock with the remote.
Old Dec 27, 2006 | 07:46 PM
john35thss's Avatar
I had the same problem with my car, tried just about everything finally I fixed it. I pulled the bulb
John
Old Dec 27, 2006 | 10:06 PM
From my Tech Page about VATS:
If the system detects a fault with the lock cylinder circuit after the engine is already running, the SECURITY lamp will light. The engine will be able to be restarted. This is called “fault enable mode”. (The system saw a good reading from the key at one point during a previous ignition cycle before the failure. So, it considers it a problem and not someone trying to steal the car.) When in fault enable mode, PASSKey protection is disable until the problem is repaired. Once repaired, the SECURITY lamp will go out about after about 1 minute after the key is turned on.
More info in the link posted above.
Old Dec 27, 2006 | 10:32 PM
Don350k's Avatar
Mine goes on from time to time and turns off, most of the time it is on a cold start and will stay on for approx 15 miles and shut off and i wont see it for approx 5 more cold restarts
Don
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
