need help with shift points
Old Dec 5, 2006 | 10:26 PM
BeaversTA's Avatar
I changed my gears from 3.43 to 3.73 and changed the shift points in the tune to shift at 5900rpm and the correct mph. Now at WOT the eng will spinn past the shift points that I set. Would any of you pro's be willing to take a look at my file and tell me what I did wrong. It is a OBD2 LT1 edit file.
Old Dec 6, 2006 | 02:08 AM
Red on Red WS6's Avatar
I have the same problem but it is not because of tuning it's because the transmission is on it's last leg. It just bounces off the 6300 rpm rev limiter after I go past 5900 RPM in 2nd gear. I had to up the line pressure and drop my 2-3 shift points to 5900 rpm to make it shift at WOT. So far so good, just saving up for a rebuild.
Old Dec 6, 2006 | 07:22 AM
sbs's Avatar
sbs
You are telling it to start shifting at 5900 rpm. It takes several hundred more rpm to finish shifting.
Old Dec 6, 2006 | 08:36 AM
Sweetred95ta's Avatar
Exactly. Shift points are something that you need to play with. You definitely can't just set them and them be perfect. Tweak the parameters until it's doing what you want.
Old Dec 6, 2006 | 11:34 AM
Well looking at the tach it shifts now at around 5900 rpm give or take a few hundred rpm on the 2-3 shift, to be more specific for you I think it is at 71 mph though. It takes the tranny .2 seconds to shift I don't think that is a couple hundred rpm's in second gear. I could be wrong though. Like mentioned above it is some thing you have to keep messing with to make it work.
Old Dec 6, 2006 | 04:28 PM
sbs's Avatar
sbs
I was addressing the OPs problem not yours...
Old Dec 6, 2006 | 04:38 PM
BeaversTA's Avatar
I belive I have fixed the problem now thanks to Kyle@CSS. Thanks guys
Old Dec 6, 2006 | 05:34 PM
sbs's Avatar
sbs
Hey hey hey! You have to tell us what the solution was!
Might help somebody in the future doing a search...
Old Dec 6, 2006 | 06:08 PM
Kyle@CSS's Avatar
No problem. If you run into anymore problems let me know.
Old Dec 6, 2006 | 10:10 PM
BeaversTA's Avatar
The computer must meet both the RPM and the MPH before it will shift. So I lowerd the MPH table down by 6mph and left my RPM table at the RPM I wanted it to shift at. If you want to shift based on MPH just lower your RPM table.
Old Dec 7, 2006 | 02:45 AM
slayer_4213's Avatar
gfl
dylan1303
Aug 12, 2015 02:00 AM
dylan1303
May 22, 2015 12:24 PM
number77
Sep 6, 2002 01:29 PM
96z
Sep 5, 2002 07:53 PM
