ls1 timing vs lt1 timing
Old Nov 16, 2006 | 11:10 AM
kyle97's Avatar
I want a sanity check to make sure i'm not making things up:
It seems like from most of the reading ive done on this forum and ls1tech, most H/C lt1s like somewhere between 35-38* max total timing at WOT (as reported by a scanner) whereas most h/c ls1s like a signifcantly lower amount -- something like 25-28* max.
Is this consistant with what y'all have seen?
Old Nov 16, 2006 | 11:44 AM
VinceTrifecta's Avatar
Yup. I've seen that too. I've read that for whatever reason, the LS1s require less advance then the LT1s.
Old Nov 16, 2006 | 02:33 PM
kyle97's Avatar
Cool -- have you ever seen any info on why?
I would think its a combination of the LT1's reverse-flow cooling and the LS1's better combustion chamber design.
Old Nov 16, 2006 | 03:32 PM
Most likely has to do with the flame propagation from the plug. And that depends on the shape of the combustion chamber, shape of the piston top, the location of the plug, the turbulance of the charge caused by inlet valve swirl and the quench/squish, etc.
rideordie
Nov 5, 2019 04:52 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
Ude-lose
71
Jul 17, 2002 04:52 PM
