Possible 93 PCM causing me Problems!
Old Nov 10, 2006 | 12:56 PM
asudecat's Avatar
I bought a PCM out of a junkyard in Dallas and im wondering if it's a 93 PCM now.
First off i've had all kinds of wire Probs. mainly with the BCM.
But I just purchased TunerCats & Datamaster and I cannot read the PCM in Tunercats and the Datamaster keeps loosing connection. Also reads 128MPH at Idle sometimes.
throwing many codes. 43, 48 mainly.
I have a 96 formula and purchased the 94-95 software for TC and DM.
Old Nov 10, 2006 | 01:01 PM
asudecat's Avatar
Also would a 93 PCM in my 96 cause BCM problems??
Old Nov 10, 2006 | 07:17 PM
asudecat's Avatar
scratch that it's a 94 or 95 PCM.
I have the right def file as well. Also tried slowing the bit rate down.
any suggestions
Old Nov 10, 2006 | 08:39 PM
byrons1502's Avatar
you need to check that the wire colors are correct for the different pcms and getting it running first before tuning. sounds like a bad ground or power problem. possible bad computer
Old Nov 11, 2006 | 12:32 AM
rkinney's Avatar
You'll know if it is a 93 cause it will have the panel to access the chip. A 93 pcm will not work in your car.
Old Nov 11, 2006 | 01:25 AM
VinceTrifecta's Avatar
Sounds like you might have a faulty PCM. I'd be tempted to take it apart and make sure there's no water in it, or corrosion.
Old Nov 11, 2006 | 12:27 PM
asudecat's Avatar
ok heres the deal. I already have had it dyno tuned and it worked fine. It is in fact a PCM from either a 94 or 95 camaro. That's the thing I dont get that it has already been tuned and I cant get it to stay connected That's why I dont think it's a bad PCM.
The tuner used lt1edit and I have tunercat. I must be doing something wrong.
Yes I still have a problem with the BCM as well but im having to jump the Theft deterrent relay to even start the car. But I dyno tuned with it like that. Then we checked over all grounds and added 3 grounds from the block to the chassis.
Im at a loss. And I have the right def file im sure.
Im just at a loss
Old Nov 11, 2006 | 12:28 PM
asudecat's Avatar
is this cable ok??
http://www.aldlcable.com/sc/details.asp?item=aldlobd2u
with my 96 and obd1 conversion?
PCLZ28
Dec 24, 2015 05:19 PM
dirtybird81
10
Jan 6, 2015 09:31 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
GigaMp3z
Feb 20, 2003 02:57 PM
DarkHorse
Aug 3, 2002 10:17 PM
