View Full Version : N2O Tech
- Window switch?
- Where to get bottle filled in Southeastern NY?
- If it burns gas
- FP gauge on stand alone?
- T-fittings from Nitrous Outlet
- LE2 LT1 with 75-125 shot. Do I have to change plugs?
- Mail Order Tune
- Nitrous and Mallory 685 wiring diagram
- how much nitrous is too much....
- dual foggers in a intake elbow,
- flo-through manifold is leaking....
- What tubing for direct port?
- NX intake, NXL DP system, 85mm TB
- what head gasket for my lt1 383 with nitrous
- Spraying too much?
- nitrous and fuel gauges?
- TB or TB boot for nitrous jet?
- Going pig rich when spraying
- edelbrock
- well its in and spraying......
- Carbon Fiber NOS bottle
- Dyno Tune/dynotunesales on Ebay, heard of them?
- no extended pressure on noids, but......
- Bending a blow down tube??
- dry kit
- Lifting heads
- Did You Know Part 2!!!
- Adding a Spray Light
- Clearenced Airbrushed Bottles
- CC503@114 or CC503@112 when spraying
- How many use a fuel pressure gauge?
- wiring the 685 with MSD harness
- some teflon tape on NPT fittings?
- quick blowdown tube question....
- 150shot ?'s
- LT1 75 shot, what plug?
- adding a fuel pressure safety switch to this schematic....
- Anyone from nitrodaves...
- February Tax Time Specials!!!
- What needs to be forged?
- Did you know part 1!!!
- Dry kit Walk threw guide?
- Which Kit???
- special thanks to.....
- what spark plug with 100-200 wet shot.
- new to the nos
- ok 1st time
- Sprayed first time and some problems
- question about a new product
- Fogger nozzles in an LT1 intake
- small bottles
- FS: 15lb Bottle ( Used )
- Any of you guys hit the spray at high speeds?
- Max RPM's
- need help want nitrous on my 383
- extreme cold bad for solenoids?
- Upgrading for 200 shot
- New Product!!!
- NOS Jetting sizes
- Installation time?
- a couple beginner questions
- Nos Tb.
- Safe max shot out of a single fogger?
- jetting??'s
- January Nitrous Specials
- 500 hp DIY plate
- How are O2's effected by N2O??
- anything wrong with using a cheap N2O filter like this...
- stock fuel pump with wet kit?
- Harris speed works ltx dual nozzle.
- Which Adapter Needed for 685 Box??
- Nitrous Accessories
- typical problems of direct spray?
- Spray how?
- Thinking of Zex controller on to maintain prefect "mix"
- Looking for Nitrous friendly pistons?
- Where to mount n20 lines
- Nitrous on a 3.9L '06 Impala
- Nos on a Six Speed, Hard to drive ?
- Instructions to install wet nozzle nitrous system???
- Harris Speed works ATVANTAGE
- Help with nozzle location
- Does nitrous make outside noise?
- busted braided nitrous line...
- simple 685 question
- Buying Nitrous... few questions????
- Post pics of your N20 gages and switches...
- wire setup and pressure gauge
- will factory crank and rods handle a 225 shot?
- Mallory box in trunk?
- MAHLE pistons vs N20
- nitrous question
- So you wanna Spray an LT1
- New Product!!!
- solenoid location
- problems
- I like the 685, but I want 1st gear lockout. Options?
- bottle fitting question...
- I need some quick answers if you would not mind!
- We need your feed back!!!
- Picture request
- Guess who won 220.00
- Mallory 685/MSD Wiring
- need the fitting that threads into the nozzle
- Merry Christmas.
- frequent bottle removal....
- How to add a window switch?
- nitro daves
- Get Your NX Bottle Blankets CHEAP!!!
- I'm confused about timing retard
- Safe to install with full bottle?
- Nitrous line for fuel line?
- 4AN or 6AN
- Direct Nitrous Setup
- New fuel pump?
- how much timing to pull?
- Some mustangs to pick on..
- Spray out of the hole/ don't spray in 1st Q's.
- Mounting Solenoids
- Pop Pop pop
- Anybody know Holley inline booster pump flow???
- adding nitrous???
- Battery and N02 in spare tire location.
- What TPS wire for activating nitrous?
- Whats the most anyone has safely run their LT1 on......
- New to nitrous with 685 questions.
- 100 shot and MadZ28 Tune
- Last Minute Christmas Special
- Most effective way?
- Nitrous Installation Kit
- First Gear Lockout question (window switch)
- Fuel Preasure and a plate kit
- spray before the MAF?
- how high can you go to on a nitrous plate?
- Dry vs Wet....
- LT1 2 Step Colder Gap?
- wondering how i should do this....
- new best time for 2.73 car!
- diomond pistons
- Fuel Pump for 100 Shot Wet?
- Nitrous Outlet Christmas specials.
- 200k, stock bottom end, 150 shot?
- Dyno Tunes Nitrous Kits
- NOS Noszle question
- And the winner is...
- How About An Extra 220.00 For Christmas
- Holiday Kit Specials!!!
- Hit it for the first time!!!
- Timming retard boxes
- Pictures of an LT1 with nitrous installed, NOT hidden.
- what would you have to do if you wanted to switch from a wet set up to a dry set up
- Do it right the first time right?
- Nos For My Lt1?
- new to nitrous
- Nitrous Setup Opinions Wanted
- Happy Thanksgiving
- FPSS Manifold
- Nos
- difference between wet shot and dry shot?
- Anyone shot w/ a rifle a full nitrous bottle by a fire?
- Spark Plug Question
- HSW stand alone fuel for n20 systems
- Nitrous plates
- some nitrous results on the black car
- GM847 and N20, what specs?
- coatings
- buying nitrous oxide
- Differences between NX All GM EFI Stg 1, and the Ford, Dodge, universal kits ???
- cold fusion
- Nitrous Express Kit Compatability
- Free Airbrushed Bottle
- 100HP the best bang for size?
- anyone else with a BBK TB and a TNT nitrous setup?
- Fuel Pressure issue???
- nitrous leaking past solenoid
- ??? about a baby dry shot
- N20 Newb
- Air Leak!
- nos dry sys. 2nd solenoid
- May be a stupid question.
- Free Free Free Free Free Free Free Free
- Fuel Pressure Cutoff Switch ---
- New NX products for 07
- Can I use a ProCharger In-Line pump for a 100-150 shot?
- In line fuel pump???
- Happy Halloween
- Airbrushed Fbody bottles
- Quick plug question
- what is NPT?
- Kit installed. Pics...
- 95 z28 nos
- Good Nitrous/fuel Solenoids for 200 shot?
- nitrous works LT1 system(prolly lots of others too)...
- how to make sure the mallory is pulling timing
- need advice
- rev limiter 1996 trans am
- can bottle be in cab with you?
- simple question about FPSSs
- Why does Nitrous cause detonation?
- what hp shot could be used safely?
- nitrous works plate system, oppinions on the kit
- Window switch problem can anyone help??
- N2O issues - detonation
- The Black Widow #2
- Anyone on here using a remote opener?
- This everything I will need for a safe N20 set up?
- Pro's & Cons of using a Mallory 685 as window switch?
- Anyone else use RTV to save space?
- Check out my Helmet
- Nitrous Outlet's Boooorific Specials
- Custom Airbrushed Nitrous Bottles (PICS)
- New News at Nitrous Outlet!!!
- longer throttle body bolts?
- quick help with my installation
- cold fusion
- what causes
- what would be better for a small shot on a high mileage motor
- Nitrous Works LT1 Kit questions, for the users, please help!
- piecing together a kit, please recomend.
- painting my nitrous bottle
- NX Kits
- What plugs with 100 wet lt1
- Nitrous Express Price Increase!
- 255lph necessary for a wet 125-shot?
- noszle system
- window switch neccesary for M6?
- lt1 direct port pics
- Just bought a Venom Dry Kit and have many Q's
- Block off plate for switches?
- Just got nitro, whats the 411?
- How did you guys route your purge?
- hey guys
- What Window switch are you guys running?
- Q on Dry Kit MAF efficency...
- LE1 w/100shot
- 125 shot...should I throw on a cam?
- Question about nitrous.
- NX kit
- Does this exsist?
- What size shot is this?
- 2 NOS dry kit questions
- lt1 wet/dry kit
- Shift points and shift light Q ....
- how much would you spray on my setup?
- nitrous management units; most cost effective buy??
- nitrous lines... earl's pro lite 350 hold nitrous pressure??
- need mounts for roll cage
- Little Nitrous question...
- TPS signal wire?
