Max RPM's
Old Jan 25, 2007 | 02:48 PM
lt1 kenobi's Avatar
Max RPM's
Stock bottom end lt1 100-150 shot... say it makes power up to 7k. Is it safe to spray to that high of an rpm on the stock bottom end???
Old Jan 25, 2007 | 02:54 PM
magicvega's Avatar
If you spray it till 7k you will be picking the pieces up shortly after. I think most people spray about 300 rpms before they shift..
Old Jan 25, 2007 | 07:09 PM
jsetzer's Avatar
Seriously doubt you are gaining power that high up with a stock bottom end. Even if you had a 250 / .650 + cam.
You will have tiny pieces in the end. N20 usually brings down the shift point a decent amount.
When I was stockish with just full exhaust @ 275whp I sprayed 150 shot and peaked HP @ 4500 rpms. There will be so much tq that you dont need to spin high on your setup. I spray till 6500 now with an 847.
Old Jan 25, 2007 | 08:32 PM
lt1 kenobi's Avatar
I guess what I'm saying is if my car does make power on up through 6500 then can I spray it up that high..??
Old Jan 25, 2007 | 08:39 PM
jsetzer's Avatar
Stock bottom end I would say no.
What else is done? Just trying to figure out where the 7k or 6500 is coming from?
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
KYWes
Sep 26, 2015 08:49 AM
Daluchman1974
Sep 11, 2015 06:12 AM
