January Nitrous Specials
We are off to a new year. I hope everone had a nice and safe Christmas. To kick off the new year here are the January specials. (sorry they are late).
NOTE:Nitrous Outlet uses only the best products in there nitrous systems.
All the Nitrous systems in the following group specials come with solenoids designed to flow 300hp, Nitrous solenoid has purge port design, The bottle valvewill flow 800 hp and has two accessory ports, quick release stainless steel bottle brackets, 16 ft main feed line,2 ft hoses from solenoids to nozzle, and all the needed hardware to complete your install.
(Dry systems have a 20 ft Main feed line)
Group 1
GM single nozzle Wet system
Fuel pressure safety switch
Nitrous pressure gauge
NHRA filtting
Blow down tube
860 Heated bottle bracket
Nitrous Outlet purge kit
Digital dual window switch (Has built in TPS and any gear lock out feature)
NGK TR6 Spark Plugs
COST-875.00
Group 2
Your choice, F-body or GTO Dry Halo system.
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 799.99
Group 3
Nitrous Express 4 solenoid Directport system with 10lb bottle
Rail upgrade
Billit Rail Brackets
Plumbed to your LS1, LS6, LS2, LT1, LT4,intake with Hard line
Cost-1700.00
(add 250 for braided hoses)
January Clearence items... (while supplies last)
1. Fill your bottle with out having to remove your remote bottle opener. This remote controll opener box works off of 9 volt batteries and plugs right in.
Only 29.99
2. Nitrous Express Power Booster.
Cost-10.00
3. NOS Purge light.
We have RED & BLUE
Cost-29.99
You can call in your order toll free at 1-866-648-7637
Thank you for your support.
Dave
Group 1
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST-875.00
Group 2
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 799.99
Group 3
Rail upgrade
Cost-1700.00
Only 29.99
Cost-10.00
3. NOS Purge light.
We have RED & BLUE
Cost-29.99
Dave
Aug 7, 2015 01:26 PM
Aug 5, 2015 08:35 AM
