Nitrous and Mallory 685 wiring diagram
I don't mind, Dave. Just send me some bottle brackets or something.
This is courtesy of another member here, but I deleted the PM and can't remember the name. If anyone has a pic of how they mounted the WOT switch on the LT1, that would help me. I think I just have a microswitch.
EDIT: Can you explain how the microswitch works? Such as, when it's pressed in, it does this and when it's open, it does this. Thanks.
Basically, the microswitch is routed in series with the nitrous circuit and is normally in the open position causing a break in the circuit. When the switch is pressed, the contacts in the switch close, creating a closed circuit that allows current to flow and thus causing the nitrous system to activate.
yep mines similar to rays. i used the a lockwasher and a few washers to space it out where i wanted it. also bent the little switch lever to get it right where i wanted it. il snap a pic next time i have a chance.
So how could I use one to only work when it was "open", as in making a first gear lockout with it? Is there someway to wire the activation relay up to where when the microswitch is pressed, then it stops the system from arming?
