small bottles
Old Jan 26, 2007 | 01:59 PM
GoFast908Z's Avatar
Member
small bottles
what size bottle will fit btwn the rear speaker in the sail panel and a Stealth subw. box? 5lb? 2(1/2?) lb?
here is the space available:
It does go down to the bottom, but there is only a few inches of room at that angle:
on the smaller bottles, i noticed they have a motorcycle valve.....what does that mean? that it won't work for a car?
I saw some really thin and tall bottles, 10 oz i think. Can you connect like 3-4 of them together?
Old Jan 26, 2007 | 02:43 PM
Ray@NitroDaves's Avatar
Here are some bottle measurements so you can see which one might fit. Some of these will not fit but I put them in for measurement purposes.
10 0Z MINI-BOTTLE (W/MOTORCYCLE VALVE) (2" DIA. X 15.09" TALL)
1.4LB BOTTLE (W/ MOTORCYCLE VALVE) (3.2" DIA. X 11.38" TALL)
2.5LB BOTTLE (W/ MOTORCYCLE VALVE) (4.38" DIA. X 12.37" TALL)
5 LB BOTTLE (STANDARD PF VALVE) (5.25" DIA. X 17.64" TALL)
10 LB BOTTLE (STANDARD PF VALVE) (6.89" DIA. X 20.19" TALL)
12 LB COMPOSITE BOTTLE (PURE-FLO 100+ VALVE) (6.79" DIA. X 23.25" TALL)
15 LB BOTTLE (STANDARD PF VALVE) (6.89" DIA. X 26.69" TALL)
The motorcycle valve is a little smaller that the standard 45* Vavle. It will still flow 400hp and it has the standard -4 hook up for the mainfeed line.
Old Jan 26, 2007 | 03:44 PM
GoFast908Z's Avatar
Member
thanks ray, i saw your post on the other board. I measured and it looks like the 2.5 or the 1.4 MIGHT fit. Or maybe i could line up 3-4 of the 10 oz bottles?
Old Jan 26, 2007 | 04:07 PM
2000GTP's Avatar
Thats alot of work and expense... Could you possibly relocate your sub box to the other side? Then you can fit whatever size bottle you want back there.
Old Jan 26, 2007 | 05:15 PM
GoFast908Z's Avatar
Member
LOL no way. I'm running dual stealth boxes. I'm ok with hard work. That stereo was a lot of hard work.....kinda how i do things
I just want a small kit, probably 75-100 max, dry shot most likely.
Old Jan 28, 2007 | 12:14 AM
GoFast908Z's Avatar
Member
what size bottle would fit (with bracket) under these:
http://www.speedspecialty.com/store/...duct=rrseatcvr
Old Jan 28, 2007 | 09:11 AM
Copied from the link you provided...
Not only do they look great and save weight, you can hide an amplifier under them (approx. 14"x14" of room, optional cooling ports available) or modify them to hold speakers.
from that information these should work
Quickss96
Jan 29, 2016 05:56 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
SEOJustin
Sep 24, 2015 04:39 PM
mmf_1013
Sep 12, 2015 08:56 PM
