simple 685 question
Old Jan 8, 2007 | 11:38 AM
69z-28's Avatar
simple 685 question
i have a 6 speed and ill be running the 685 for retard and window switch. well my plan at the track is, launch, then after i grab 2nd gear, arm the system. will this activate the window switch and timing retard on the fly? or will i have to play with 1st gear until i can hook up?
Old Jan 8, 2007 | 12:06 PM
69gto96z's Avatar
As far as I know it does, once it sees power to the wires that it uses for the window switch and retard, it sets everything.
Old Jan 8, 2007 | 12:55 PM
2000GTP's Avatar
The nature in which the window switch and timing retard are hooked up in conjunction with the nitrous kit and ignition will make it impossible to activate the box when you want.
Old Jan 8, 2007 | 01:53 PM
69z-28's Avatar
2000GTP, so your saying i will need to activate the nitrous system to activate the retard and window as well, at another time, instead of on the fly?
how else can i use this setup without spraying in 1st gear?
thanks guys.
Old Jan 8, 2007 | 01:57 PM
MichiganSkip's Avatar
Yes you can do it If you need help PM me. I do this stuff all the time
Old Jan 8, 2007 | 02:06 PM
69gto96z's Avatar
Are u wanting to leave the box running at all times or only when you want to spray?
Old Jan 8, 2007 | 04:23 PM
CamaroSS30thAnn's Avatar
YES! once u hit 2nd gear just arm the system
everything else will just go from there
there are different opinions on whether a High ignition system will shorten the life of ur opti....... honeslty i dont care lol i run mine all the time , in order to get the box to come on only when u use the nitrous (if possible) is a waste of time.
Old Jan 8, 2007 | 04:27 PM
69gto96z's Avatar
Agreed!
Old Jan 8, 2007 | 08:03 PM
69z-28's Avatar
well i was planning on running the box all the time, but i only want the window and retard activated with the nitrous obviously, so the box will constantly be hooked up, however id like to know if i can turn the retard and window on at the flip of a switch.
i actually dont even have the kit in yet but i hate waiting for parts/information so i want to make sure everything will go as smoothly as possible and i can begin using it/testing it ASAP.
Old Jan 8, 2007 | 09:17 PM
69gto96z's Avatar
Yes, once its all hooked up, when u arm the system the box will set the window switch and retard the timing.
Old Jan 8, 2007 | 09:25 PM
69z-28's Avatar
sweet, thats **** and beer dude.hehe
Victor Lamb
Aug 26, 2017 02:52 PM
Hurin
Dec 13, 2014 07:38 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
