anything wrong with using a cheap N2O filter like this...
http://store.summitracing.com/partde...5&autoview=sku
or would this be smarter?...
i wasnt planning on even running one but i figured if im doing it the right way il do everything right. also, with a purge kit, would this effect the placement of the nitrous filter?
thats what the pic looks like, but i beleive it is in fact a small filter no? the description clearly states it is a filter, but i agree it looks like a small adapter.
heres a better question...
according to Dynotune's website, some of the NX solenoids have 1/4 NPT as opposed to most other brands that feature 1/8NPT.
it says this here...
http://www.dynotunenitrous.com/store...s/prodView.asp
heres me solenoids, nitrous on left, fuel on right. that looks like a 1/4"NPT inlet compared to the smaller fuel fittings doesnt it? so i would need the larger filter fitting. please confirm for me.lol
sorry for craptastic pics too.
Those are both filters the first one has a screen in the side that goes into the solenoid. In all honesty the filter fittings work pretty good I don't think you would have any problems running them. And they come in diffrent sizes. A 15560 would be a -4 x 1/4 NPT and a 15568 would be a -6 x 1/4 NPT.
i saw that Dave, however its a little more than i want to spend. im gonna go with the dynotune filter and screw it right into the inlet of the N2O solenoid and hook up the main bottle line to that. i beleive that will take care of it.
im sorry i thought you were referring to these...
http://www.nitrousoutlet.com/catalog...del=78&dept=11
can you guys send me a link to the filter fittings you have available, i searched around on your site but couldnt seem to find what were talking about now.
The filter fittings are not listed on the site at the moment...
they look just like this but have a filter built into the fitting...similar to the NOS one you posted first....
http://www.nitrousoutlet.com/catalog...roduct_id=2012
alright great. when i call in the next week or so and make my order, should i just ask for the -4an to 1/4 NPT filter fitting? this would allow me to hook the main line to the -4an and the 1/4NPT directly into the inlet of the N20 noid correct? do you have a part number i can just tell them when i call? thanks a lot for the help everyone, especially Ray and Dave.
also, where will the purge solenoid need to be hooked up to the N2O noid? will i need a seperate adapter fitting or anything? i was planning on using a purge kit for -4an obviously and then the kit has 1/8" fittings. would i need a different adapter to go into the bigger 1/4 NPT fitting on the NX noid or what? like i said, im not sure exactly where the purge noid will go in relationship to the feed line and the noid and filter and everything else.
ok i think i have it figured out actually. would this work....
this filter fitting from the main line, into my 1/8"NPT purge noid...
then outa the purge this adapter directly into my N20 noid....
http://www.nitrousoutlet.com/catalog...roduct_id=1989
that would be all i would need correct?
yes it does!!! i forgot about that, it has a plug in it now. i bought the kit used so its kinda goofy, but your right there is a purge on the opposite side of the 1/4" inlet. would the filter fitting go between the main line and the noid then, and purge on opposite side with outlet just on the bottom? that would be a better setup and wouldnt need as many fittings. thanks again!!!
the filter fitting you need would be a 1/4x-4...it would go on the inlet for the nitrous solenoid and the feed line would attach to the filter.
SpeedJunkee
Jun 6, 2015 04:27 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Deadbolt24
Jan 19, 2015 01:29 PM
Dec 1, 2014 08:08 AM
