View Full Version : N2O Tech
- lt 1 nitrous plate question?
- Digital Dual Window Switch
- info on a Zex Nitrous kit on a stock LT1
- just making sure
- N20 Lt1 to LS1
- WOT switch location?
- Across America. How much to fill 10lbs bottle?
- Too many kits, can't choose!
- n20 question
- Good Idea?
- New Best Time in My 2.73 car
- lets see pics
- How big of a shot are you guys running through the TB?
- NItrous Works
- Need info. on Zex dry kit.
- Throttle Body won't fit with TNT plate?
- mallory settings
- newbe with a ?
- Possible to run both a wet and dry shot?
- need some advice with 3.4
- Whats involved in a single to dual stage conversion?
- finding jets for the lt1 throttle body nos plate
- mallory.....timing
- modules/pills.....what's the difference?
- any problems with low PSI and spraying?
- LT4 direct port fogger jetting
- Nitrous for your R/C car???
- Mallory users
- Thanks HSW
- where to run the nitrous line?
- Which type is more prone to sneeze/backfire?
- Full Line of Nitrous Express and NOS Products!
- Buddy and I are building an LT1 wet system... plate or nozzle?
- NOS 05151 wet kit on lt1
- jets? help some1
- Lookin to get the nitrous system functional after a yr, need some help
- Some pics of my NX dual nozzle install.
- nitrous gurus... pull timing for 100 wet on stock LT1?
- Nitrous Works???
- Would the NX 20915 EFI setup work with my LT1?
- New dyno #'s
- Jets in Intake Elbow
- which nitrous set up is recommended for the set i'm running
- strange problem with nitrous... please help.
- Use C16, add timing
- pro/con of dry/wet systems on stock LT1
- Intermittent NOS shut-off during run
- TPI nitrous setup...which one is favored?
- fast 90mm intake w/ blow off relief?
- does it realy matter if you heat your bottle
- bad idea to run n2o with no knock sensor?
- Anyone tried the direct port nozzle systems?
- What are you guys running 1/4 on 100 shot?
- 100or150 shot
- nitrous piston
- trying to get into 12's
- 675 HP/685 TQ HSW Brute Force Dyno Results
- timing retard
- not running right
- i am clueless, need some help
- nitrous problems
- zex
- Did search..please post 'noid mounting solutions
- Need some advice on dual stage 150/150HP?
- Just a teaser pic of my mess, err progress
- nozzle placement lt1 direct port
- Well... This is the place where I learn before spraying....
- spraying BIG for a season
- Does anyone on here sell these jets?
- Safe shot?
- opinion
- all about nitous
- 200 Shot TNT System on 95Z28 Camaro Stock
- Quick Zex Question
- 150 shot
- Any tips before going to NOS???
- Good set of pistons for a N20 car...
- NX safety nut tap size...
- When using 200hp Single shot
- Racetronix Pump
- A/F Ratio for a nitrous car
- cheap retard box?
- nitrous facts
- how can you icrease bottle temp?
- which octane to use?
- wiring for bottle heater and opener
- Problems after nitrous install
- Will TR55's cause detonation?
- track advice
- Nozzle placement with a Moroso CAI?
- Mallory 685 w/ Nitrous Works kit
- whats not enough fuel pressure for n2o
- How to wire purge and bottle heater?
- which kit
- is there a longer lasting 1 step colder plug?
- Dirt Don't Hurt?
- What size shot do you need to start pulling timing with?
- Plugs? what kind
- Stand alone set up
- Nitrogen Push...?
- stock ls1 nitrous questions
- MSD 3 stage retard
- Nitrious controller
- NX WOT Switch?
- lean on a 75 shot
- NX jet sizes
- For those with LT1 nozzle setups...
- Fogger set up
- Looking for N2O newbie reading material
- difference between ford and chevy universal nx kits
- What jets for lt1 NOS Dry 150hp w/ 48ps1fp???
- Well... Im down.. Dry Kit.. Which one?
- n20?s need advice
- Newb nitrous question
- How many heads/cam stock bottom end guys are spraying
- Window Switch Wiring Problems
- Making Your Own Nitrous Lines?
- Plz Help
- HSW bottle opener??
- Making my own kit
- Stock LS1.. Got all the NX stuff, Need Advice!
- What do you guys think of the cold fusion kits?
- Whats The Best Kit For Me?
- 396ci LT1, D1SC, 58mm NOS TBI, F.A.S.T. and NOS ......
- where to mount digital msd ignition box?
- what kind of autometer guages should i get?
- Nitrous Newb...Being tempted!
- new car with nitr4ous question
- Do I need a tune for a dry shot?
- N/A tune with 100 shot?
- Converting from a Plate system to nozzle and other ?s
- 75 shot tune or not to tune
- LTCC and MSD Digital Window Switch wiring?
- Nitrous Tuning Questions
- Mad Z28 tune-how much timing to pull?
- et time on 01 z28 with 100 shot?
- Fuel Cell Installed
- Too Much Pressure?
- still getting "detonation"
- Nitrous Or Not 108,000 Miles?
- Question about NX MAF kit
- Wiring the NX Bottle heater.
- 28lb ls1 injectors on a bolton lt1 with dry kit
- n2o gauge position
- nitrous questions on ls1
- NX solenoid rebuild ?
- Help with window switch
- All those with NOS 5176 kit inside please
- What RPM activation with 3200 stall?
- track times with 305 tbi&n20
- tapping into plastic fuel line
- what shot?
- what size jets?
- fpss ?'s
- window switch
- holley says fogger wont flow over a 150 shot!!
- Exper. w/dynotune kits? N20 Q's??
- how to activate the 2nd stage
- Can my car handle 100 shot?
- Dual Stage vs Progressive Controller
- Fuelrail fitting on my L98?
- 96 LT1 nitrous questions
- Need NX wiring diagram
- Nitrous wiring problems
- injector size for dry shot and 396 CI
- Best Nitrous Kit for my Car
- Compucar wet kit with NOS fogger nozzle and .047 and .053 jets- what hp shot is this?
- Spring Nitrous Kit Specials!!!
- Gapped Rings for Nitrous but Direct Port or Single Nozzle.
- Fuel system upgrade for boltons plus 150 shot
- lean a/f
- Part #'s on zex jets
- timing for 250 shot?
- spark knock under spray
- Plug Gap for a 100 shot?
- Injectors???
- air temp and nitrous
- nitrous dont work
- nitrous on a v6
- foger nozzal aim
- Appropriate size fuse for NX bottle heater
- i want to add a 2nd stage to my nitrous ?
- NOS fuel psi saftey switch
- value
- 365rwhp heads and cam + 150 shot?
- i am putting my nos back on after a rebuild of my engine and.....?
- Just bought a TPI Nitrous Works kit..any ideas
- Standalone fuel system. High or low pressure?
- NX bottle opener woes
- 95 Z28 Auto
- problems
- Thinking about getting N20
- somewhat new to nitrous
- Anyone using the 860 v-spray purge block?
- window switch vs. "nitrous button"
- How much abuse does 100hp dry show take on a stock motor?
- Purge valve question.
- Is this a good price? N20 bottle...
- When to use seperate fuel system?
- Likelihood of engine fire due to wet kit?
- Harlan window help
- your thoughts on how to run my Fuel Line and Blow-down tube??
- Bottle pressure???
- spray on a innercooler?
- Small shot?
- rpm - tach wierd issue 7 k bounce!?@
- What jet sizes are these??
- Spraying before MAF but on my 01 Mustang GT???
- which is the better pump for 650hp?
- 12+ switched power
- How to mount the bottle???
- Whats the best plugs for a SBC Carb motor??
- Blow downtube
- toggle switch
- Ok need some input.
- Best Progressive Controller
- Nossle placement ?
- Nitrous Express LS1/LT1 Mass Air System
- NX Gemini Twin EFI system lt!
- Viper Install
- All Installed
- Nitrous on a Stock LT1?
- Help with bottle mounting
- N2O tapped TB plate (LS1)
- Jet sizes and tuning
- What jets do I need???
- Timing question
- Nitrous and Methane?
- Plugs, wires, and ignition for N2O.
- Anyone using nito dave's dedicated fuel system for nitrous????
- Ignition Box Question
- nitrous nozzle testing
- I hit the button for the first time yesterday (also have some tuning q's)
- Mallory: Small orange wire
- nitrous
- Should I get rid of my NOS plate for a Nozzle?
- Is all nitrous the same?
- Re-fill?
- What else do I need?
- PROBLEM: Digital Dual Window Switch with TPS sensor
- Nitrous newb. 75 shot HELP!!
- Blow down tube?
- Wet system for Stealth Ram intake...
- New Mechanical Remote Bottle Opener
- I worked all day for nothing....
- plate vs nozzle
- Testing my N20 system before hitting the street??
- nitrous works lt1 plate
- April Nitrous Specials.
