Free Free Free Free Free Free Free Free
Thats right its FREE month here at Nitrous Outlet... In case you missed it I said FREE FREE FREE FREE FREE FREE !!!!!!!!!!!!!!
Group1
This one is perfect for you Corvette guys.
Our dual nozzle dry system.
This system comes with a 10lb bottle, high flow valve(side port design), 20 foot main feed line, stainless steel bottle brackets, 500 hp solenoids, 2 foot -3 hose/90 degree ends, jetting for 70-100-150, all fittings, hoses, fuel pressure safety switch, nitrous pressure gauge, nhra blow off valve, and blow down tube.
With this system you get a FREE Nitrous Outlet Purge kit.
http://www.nitrousoutlet.com/catalog...roduct_id=2184
COST
499.99
Group 2
Single nozzle dry system.
This system comes with a 10lb bottle, high flow valve(side port design), 20 foot main feed line, stainless steel bottle brackets, 150hp solenoid, Jetting from 50-100-150, and all Hoses fittings etc.
With this system you get a FREE switch panel.
http://www.nitrousoutlet.com/catalog...del=82&dept=11
You can choose from either of the F-body ashtray panels, GTO fold up, GTO slide in, or either one of our truck panels.
Cost
340.00
Group 3
WET/ DRY Dual stage combo..
This system comes with your choice of a stock or 90 mm plate, 10lb bottle, high flow valve(side port design), 16 foot main feed line, solenoids, jetting from 50-150, all hoses and fittings. The Dry side will consist of a 150 hp solenoid, single dry nozzle, jets from 50-100-150, all needed fittings and hoses.
With this system you get a FREE dual stage window switch.
http://www.nitrousoutlet.com/catalog...product_id=964
Cost 825.00 (97-04 vette add 25.00 or GM Truck add 30.00.)
Group 4
Plate system.
Your choice of the stock or 90mm plate system,10lb bottle, high flow valve(side port design), 16 foot main feed line, solenoids, jetting from 50-150, all hoses and fittings.
With this system you will get a FREE Switch panel.
Cost 650.00 (97-04 vette add 25.00 or GM Truck add 30.00.)
Group 5
NX single nozzle system. Part number 20920-10
http://www.nitrousoutlet.com/catalog...&product_id=68
Cost 609.00
!!!!!!!READ THIS!!!!!!!
1. Now here is the sweet part for everyone. With any purchase over 50.00 you will recieve a FREE NX octane booster with your order.(while supplies last)
2. With any purchase placed in the month of November you will be entered in a drawing for a FREE custom painted Nitrous bottle. You will need to tell us what site you read this on!!!
You can call in your order at 1-866-648-7637.
This special is good until the end of November...
Dave
Group1
COST
499.99
Group 2
Cost
340.00
Group 3
Group 4
Plate system.
Group 5
Cost 609.00
Dave
You only get the FREE switch panel with it for the month of Nov. The system normally goes for $349.00 but will soon be going up on price a little bit. I replied to the black widow thread.
-Chris
Aug 24, 2015 06:41 AM
Aug 7, 2015 01:26 PM
Louey
Pacific
Aug 7, 2015 01:47 AM
Aug 5, 2015 08:35 AM
Jul 17, 2015 02:47 PM
