Fuel Pressure Cutoff Switch ---
Old Nov 2, 2006 | 02:45 PM
AlwaysCode390's Avatar
Question Fuel Pressure Cutoff Switch ---
I will be running a 125hp shot of dry Zex and was recommended to use a fuel pressure cutoff switch. What are you guys running? What company/part number should I look for (so I can make sure it fits). I have a walbro 255lph pump already. Thanks ---
Old Nov 2, 2006 | 04:31 PM
Ray@NitroDaves's Avatar
This is the FPSS that NX sells
http://www.nitrousoutlet.com/catalog...product_id=250
What ever company you decide to buy the switch from you will need to make sure you get one for an EFI high pressure fuel system and you will also need a manifold.
Old Nov 2, 2006 | 04:37 PM
2000GTP's Avatar
I'm running the NX piece, the one in the link above to be exact.
Old Nov 2, 2006 | 04:47 PM
it is on my car also
Old Nov 3, 2006 | 09:25 AM
HarrisSpeedWorks's Avatar
Another option would be ours:
http://www.harrisspeedworks.com/shop...cat=313&page=1
Since you will be running it with a dry kit make sure you get an AN cap to cap the other end of the manifold so fuel doesn’t shoot out everywhere lol:
http://www.harrisspeedworks.com/shop...roductid=16823
Thanks,
Matt
Old Nov 3, 2006 | 10:41 AM
They are all basically the same part... made by Hobbs (part of Honeywell).
http://content.honeywell.com/sensing...bbscorp/P2.pdf
Old Nov 3, 2006 | 10:45 AM
Oh , I see.... thanks guys ---
BTW How big is the bottle (lb) on the dry zex 82018 lt1 setup I have? I have that setup, with a purge kit, safety blow down, bottle heater w/ bottle cover, pressure gauge, and a purge light .... I will be ordering a safety fuel pressure switch and remote electric bottle opener, is there anything else you all recommend? I am using a walbro 255lph pump. Thanks ---
Old Nov 3, 2006 | 11:08 AM
The Zex kits come with a 10# bottle.
PM replied to
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jul 4, 2005 05:00 PM
F(ast)-body
Feb 26, 2003 09:05 AM
