Safe max shot out of a single fogger?
Old Jan 19, 2007 | 06:26 PM
Loadre's Avatar
I'm currently spraying 200 but was thinking about stepping it up some more. Is 250 a problem on LT1s through a single fogger? My nozzle is located in the short side turn of the elbow before the TB. Any feedback is welcome. What's the max safe shot some of you vendors use for a single fogger?
Old Jan 19, 2007 | 09:00 PM
Ray@NitroDaves's Avatar
Which brand single nozzle kit do you have...Solenoid size, nozzle, etc....
Most of the Larger brands will support a 250 shot on a single nozzle....the thing to watch for is distribution problems.....with the larger shots you could run into a "hot" cylinder....even though your gross AF is within the limits you could have individual cylinders having issues...reading spark plugs will help identify this before you have a major problem.
There are also a few questions that will help me know what can be done to help you step up the shot....
What plug are you using?
What fuel system do you have?
Old Jan 19, 2007 | 10:07 PM
Loadre's Avatar
NX 20920 kit with an SHO line. That's moreso what I was asking. Is a 200 shot reasonably safe as far as individual cylinder temps? What becomes the point where we have to start worrying about one cylinder getting too much?
Autolite 103 plugs for the 200 shot. 36# injectors and a racetronix pump, will probably upgrade to the wiring harness before I step it up any more too.
cmsmith
Sep 14, 2015 09:25 PM
nd4spd200
Aug 21, 2015 09:30 AM
Slayer
Aug 17, 2015 03:55 PM
Cam's maro
Aug 11, 2015 07:45 AM
NewsBot
Aug 3, 2015 02:40 PM
