View Full Version : N2O Tech
- Is an ignition box really needed???
- jet sizes
- hows this sound.....
- Mounting NOS Nozzle
- Quick NOS jet question on a 3.8lt...
- Is TNT's F-2 kit 100-250, or 100-350 HP? Page says both?!?!
- Juice and Motor Problems!!!
- Nitrous Newbie
- Steering Wheel Controls
- NX TPS switch bit the dust
- i noticed a big difference in jettings for various hp levels
- how does this kit look??
- sprayed the N2O, my thoughts
- With a Golen short block...
- bog when wot switch is activated
- Anyone running a TNT plate kit with a monoblade?
- How much nitrous can she handle?
- RPM activated switch
- mounting nozzles inside intake?
- What MSD box to use to retard timing?
- TNT kit with no plate
- Flamability
- How many Relays for Nitrous set up?
- How do I wire a N2O cut-off switch on my clutch?
- LS1 Nitrous
- N20 (wet) fuel source from stock 4AN fitting
- Nitrous and propane
- Earls Pro-lite 350 and N20 Can you do it?
- How much is too much with my CR?
- Help me wire my Accel 300+ with an MSD Retard control
- cheapest N2o ,where??
- Race, using nitrous. Advice needed.
- ok got everything spraying now....i think :(1
- NX system doesn't work, schematic inside
- where on the back of the fuel rail do i take stem out and hook fuel line for n20?
- Msd 8970
- Help me wire in my bottle heater
- NX remote bottle opener
- 150 shot
- Anyone running NX MAF setup?
- would this hurt my injectors on my TBI?
- I have fallen victim.... to NOS!
- a crazy question
- Nitrous Works and Nitrous Express
- How much retard for 75 shot?
- Msd 6al
- New Dyno Numbers
- People with aftermarket TB's inside please.
- anyone run this kit?
- Anyone try this for their bottle warmer?
- Anyone running this setup?
- Mallory modes.
- How much should I spray?
- Instructions for old style "Maximizer"???
- people who R running a fuel presure safty switch ? please!!!
- WOT switch options with a 58mm BBK tb...
- Dry nitrous questions - newbie
- fuel presure safty switch ? PLEASE
- Bottle heater users please enter!
- 5176 Dry to wet conversion question.
- how much nitrous on a 400 horse head/cam LT1
- nitrous help please
- Fill me in on how to hook up dual atage system!
- cheapest place to buy a n20 kit ?
- GM 847 and 150 SHOT?
- will an fittings hold nitrous pressure levels?
- lt1 nitrous kit with all the goodies for sale
- How much does bottle pressure really matter??
- Relay wiring diagram??
- Dual Stage
- Fuel line valve core
- OK to fill half full bottle with CO2 for intercooler sprayer
- spraying an LS1 on a motor tune????
- light weight pistions & Nos
- Gas question on a wet kit
- Finally have my 355.. How much spray should it get??? :)
- BG Nitrous Works bottle heater finally available ...
- Trying to squeeze the biggest shot out of a single stage system
- TNT kit with a mono blade?
- zex kit
- What fuel to use in the Fuel cell for 300 shot?
- Just bought a Nitrous works kit for the LT1....
- How do I polish my Nitrous Works bottle???
- 1st incident with carbed nitrous setup.
- For those running 250+
- Retard
- first time using nitrous
- How many out there using remote bottle openers?
- N2O ussage
- NEWBIE Nos kid. Need Answers.
- Anything I'm forgetting??
- 112 LSA and nitrious?
- Dynoed with NX
- fuel usage per run
- What plugs to use?
- NX experiences
- good adjustable fuel regulator?
- HELP! Easy question
- Do you need a separate fuel system for a heads & cam car?
- need a new noid
- dry to wet befor the maf
- jetting
- Changing the Jets
- Inside of tail pipes are white??
- NX filter
- Nitrous on a daily driver--safe?
- Help me run a 150 shot.....what all do I need?
- Mounting silinoids on top of intake for fogger setup?
- Sprayed a small TNT shot, dyno results
- TNT LT1 jet sizes
- Trying N20 at track tonight
- Retard timing with a resistor in the IAT circuit ?
- zex kit
- nozzle mounting
- NOS remote bottle opener owners come in
- will my stock bottom end handle a 200 shot?
- make a dry kit wet?
- Help me pick a camshaft!
- Iat
- Is anyone running a 150 shot with a direct port fogger?
- This week is the one..gonna go ahead and spray it
- Want to forge a 355...200 shot?
- ignorant on the spray, 'lil help please....
- Anyone use one of the new NX pressure regulators that mounts on the bottle?
- My bottle has a bent handle?!
- LT1 TNT nitrous kit and access. for sale
- nitrous on heads/cam car...think the stock bottom will take it?
- new to N2O
- Fuel for nitrous?
- is this a good deal.... if so i'll buy
- tight fittings
- jetting ?
- TNW jets..this seem right?
- new dyno numbers today
- 1st time in this section!!
- thoughts on this nitrous kit?
- Thread Sealer
- breaking up
- Ignition question
- nitrous on a freshly rebuilt cast internals engine?
- Wet kit on an LT1
- Guestimate ET
- NX Maximizer
- Direct port runner pictures
- How far have you pushed your stock injectors??
- Too many miles??`
- n2o for my 96
- Ok Nitrous Gurus, crack this FPSS issue...
- How hard to install
- Covulated tubing anyone?
- Two bottles instead of one
- N20 with a header leak??
- Nitrous Prep
- ZEX Dry kit for my LT1
- Wiring and testing nitrous
- NX wiring.
- 50 shot problems
- blow down tube.
- taking apart noid
- new high score
- The Beginners guide to Nitrous
- Nitrous and your insurance...
- NX N20 pressure guage.
- Plan to run........
- Got my Nitrous Works plate....got a ?
- edlebrock EFI nitrous kits
- cruising with n20
- Where To Get Window Switch?
- How much spray does it take to do this?
- what plugs do i have?
- Looking For Under Hood Pics
- Lean? anyone
- Nitrous line routing question
- biggest rwhp gain with NX shark nozzel
- Needing to know if it's worth it
- using steering wheel buttons.......?
- Why get a window switch?
- N2O noob, question about setup...
- what spark plugs to use on an lt1?
- A4 guys with nitrous........
- nitrous piston rings?
- Remote bottle opener question?
- NX remote bottle opener question
- Is a dual stage safer?
- Installing my NX 150 wet kit, help please
- 100 shot w/out mods?
- Need a 200-250 HP adjustable wet kit
- TR6's Gap??
- bottle heater wiring.. this right?
- solenoids not clicking
- recomended reading?
- compucar kits grinding thermostat?!?
- pressure diffrence between bottle and noid?
- questions about nitrous restrictions (hardware)
- Digital MSD window switch?
- Whats so special about the NX bottle blanket?
- Making a dry kit a wet kit need some info
- N20 and police....
- Window switch problem?
- What RPM Pills To Use On Stock A4 95 LT1
- Did i get a bad batch?
- Mounting solenoids?
- Good cam with N20.
- I need a 5,500 MSD pill
- will i need bigger injectors?
- Parts for LT1 Wet Kit
- NX Wet Kit and Schrader Valve
- Propane With N20
- ported heads with nitrous?
- hooking up nitrous switch
- what do i need?
- 400rwhp n/a, how much spray on stock bottem end?
- please help ! fried wires installing purge
- Fuel pressure for nitrous
- Spray first time without retard?
- NOS wireing setups
- Single stage setup into a dual stage?
- Nitrous is the thing for me I believe.
- jet help (dry Kit)
- activation switch
- More fuel - what are my options?
- length of fuel line from rail to solenoid?
- will a 4.6 stang wet kit work on a lt1?
- Need help mounting bottle
- Last Min Dry Kit Install Help
- bottle mounting
- Intake backfire
- Recommend a Ignition Box...
- Just bought Nitrous Works Plate System
- How Many Nitrous Guys Are Here?
- NOS kit on my 92
- should i do it??
- Where To Find Custom Ashtray Switches?
- Mechanical or Electrical N2O Gauge?
- Autolite 104's OK?
- Dry kit on an LT1
- Injector Size?
- mounting switches??
- Finished "Piston" section
- msd window switch all messed up?
- nitrous cams?
- is this a good deal?
- zex kit and me?
- N2O exam questions???
- Will she blow??!!
- Does anybody know?
- Biggest shot that you would go with setup?
- HELP!!! TNT Throttle Relocation Brackets look like they're machined by a monkey....
- Dual Stage ?
- TNT plate does not fit!
