adding a fuel pressure safety switch to this schematic....
can someone use this diagram here...
and throw in a Fuel pressure safety switch. will i need another relay?
yes, if you have a mallory run the noids into it, then the other side to the mallory...or any other window switch...if not, if its just on a wot switch then run it between the ground, it can basically go alot of places, just needs to be able to break a connection that will cause the sirsuit to fail
Jul 4, 2005 05:00 PM
