TB or TB boot for nitrous jet?
I'm 99% sure I've found the car I'll be buying this week. It's a 1996 6spd WS6. It has Nitrous on it though and the jet is in the TB boot. Now, the way it's sitting the Jet is spraying away from the TB towards the front driver side wheel instead of straingt into the TB itself. So the owner says the jet will probably only go into the driver side cylinders as it's sucked in. I'm not a physics major so I just went with it.
Now, on my brothers GTP he drilled a hole in his TB and mounted his Nitrous nozzle into that. Can I do that, or is there a special boot that I can buy that will make the nozzle sit in the right position?
Thanks.
Thanks.
If it is the NX shark nozzle you can try using the adapter (NX-15719) http://www.nitrousoutlet.com/catalog...del=88&dept=11 That should give it a more secure fit in the intake elbow where it points in the correct direction.
Devinfoote87
Jul 30, 2015 09:54 AM
