- Rev limits and Hypertech question
- Spraying my stock 305, good idea or not???
- heavy exhuast runner porting.
- Window Switch
- 6A-L for 75 bux is it a good deal?
- Looking For Pics Of LT1 Direct Port Installs
- Best time to spray?? need help ASAP
- A safe N2O Setup
- Anyone know about Zex kit for LT1
- Wich Kit?
- HELP! What's wrong with my car???
- size of fuel pressure safety switch that comes with 5176 LT1 Kit?
- ? for the TNT users
- Anyone run a seperate fuel sys. ??
- Help with ignition box settings
- Is the nozzle to close to the Throttle body
- What's the best Dry N2O setup for a 75-100 shot
- MSD window switch owners in here!
- How hard to install Nitrous
- Q about blowdown
- New Dyno with N20
- Need HELP FASSSSSST Please!
- Changing over to nitrous from supercharger need some help??
- correct injector size?
- nitrous "wet" or "dry"
- What RPM does your window switch turn on and off the nitrous?
- How much N2O is wasted through fill station
- Looking for advice on a remote bottle opener
- Quest about keeping PSI up and bottle warmed...
- Info On Direct Port Please
- Where Can A Ten Lb Bottle be hidden in a Camaro
- Head Cam guys using N20
- So if I get the progressive controller....
- N2o Geniuses Take a look
- Opinions On Bottle Location
- Quick Question.....
- 15# bottle mounting
- LS1 plugs?
- Heat + Solenoid = Bad?
- nx install photos
- Do You have to have a NOS pump on a dry kit
- What should I expect for an ET?
- Pulling timing vs. PCM tuning
- Ignition upgrade a necessity?
- Who is running a fogger?
- spark plugs
- zex for my lt-1
- NOS LT1 Dry Kit - 175 hp
- LT1 NOS Dry Kit - 175hp ?
- Which fuel cell and pump for my wet kit?
- Something whent wrong
- (Video)See if you can guess when I hit the button
- N20 + crashing car = really bad????
- N2O on my 140,000 mile 91 Z????
- Are there any window switches other than MSD?
- Looking for info on a NX direct port setup
- NOS 5177 Kit $$186.99??????
- Spraying through shifts in an auto???
- ANY WET UPGRADE FOR NOS 5177?
- My NX N20 Solenoid Melted :(
- NX jetting question.
- what kind of gas do i use while spraying?
- what does detonation sound like
- New to N20
- hidden nos????
- 103's or 104's PLEASE HELP!!
- Anyone need a MSD 6AL?
- TNT and Switch pics!
- nx switch panel
- Need help with orange spark plugs?
- Wiring diagram for msd retard box connect to msd 6a?
- Question for LT1 ZEX Kit owners
- How do I install the fpss? NX kit
- NOS PowerShot carb system to nozzle?
- Fuel needs with NX kit??
- TR6's, I cant remember, their heat range!
- 75 or 125 Zex shot on a stock 93 LT1
- Need some help from the experts. My NX kit not putting down what it should?
- Shelf life of a full bottle?
- Got feet wet at NMCA meet, now need the perfect pressure range...
- need nitrous help
- Why N20 is fun......on a rental
- New to N20
- Making a 15lbs bottle fit
- Need help on wiring switches
- NOS pill sizes?
- Plate vs. nozzel?
- NOS opener work on NX Bottle???
- Bottle is in - spare tire is OUT
- Answer to NOS on stock motor questions
- love the dope
- Best ignition setup for my N2O needs?
- how much does it cost to get a tank filled
- what is a window switch exactly and how does it work?
- adding nos to stock lt1
- In line fuel pump with N2O???
- 396 Stroker...Ready for 2-stage...
- NitrousOxide and My Geo Metro
- new to nos
- 430+ 355 with stock crank ...is it ok for a 150 shot?
- biggest shot on a Stock LT1 long block to survive????????????
- Anyone got a good "how to" site to install a NX kit on a LT1?
- Anyone got instructions on how to install an NX bottle opener?
- NX remote bottle opener?
- Getting ready to spray 150 Shot- Need tuning help!
- Where to put the Shark Nozzle?
- what store has good prices on NX
- Got a technical ?
- Cheapest ignition?
- Just rode in my friends juiced Jetta!
- cylinder pressures and spraying at low rpm
- Windows Switch Setting
- N2O Jets
- ? about carb and N20
- TB Plate? Who makes one that works well with the NX kit.
- can miss adjustment of tps change n20
- HOW can I test N2O solenoids with them wired into window switch?
- SX2 nozzle cost?
- relay???
- N2O on High Comp. 383???
- LS1
- Best kit for TPI LPE engine
- Any suggestions for taking apart a n2o solinoid and clearing out debre?
- What else do I need?
- orange plugs?? and a few other q's.
- Anyone running Nitrous Works 13070 kit?
- 150 shot and Hotcammed Lt1=?
- The ole' plug question........
- Dual bottles with dual stage???
- purge question
- Hobbs/ Fuel Pressure Safety Switch
- Nitrous switch that says "go baby" or "nitrous"
- I need some help with NOS remote opener
- What is the best price anyone bought the NX Kit For?
- Autometer air/fuel gauge not working right...need help?
- New to N20, some questions about what else to buy?
- Best system for a 75 shot
- Need opinions on Autolite 104's
- Stock engine (few bolt ons) Plus 150 shot = bad?
- Looking for info on exhaust temps..>>
- Dual Stage set up?????
- How low into the 12's will a 100 shot get me?
- Should I remove the LT4 KM before juicing?
- do i really need an rpm activation switch on my a4?
- Anybody need an extra 10# bottle?
- optimal angle for the bottle.
- fuel system capabilities.
- 11 seconds for $500
- NOS problem
- Help me hide my bottle!
- NOS bottle valve with 2 acc ports?
- Hot cam & dope= many smoked mustangs...
- Can excessive bottle heat.......
- Wet or Dry........?
- Window Switch Help ASAP
- NX jetting for 300 shot
- Experienced N2O users
- Testing my nitrous questions
- Need some help about DP .
- Wanted to check with the experts
- Vortech elbow and N2O.
- Freezing bottle before pumping?
- what kit in your opinion is the best/safest for stock lt1
- is the zex 75-125 shot a good safe kit?
- Spraying in 6th gear
- What shot?
- OFF THE LINE
- How much ?
- Ohh Bloody hell! WTF am I supposed to do with this setup!
- Why not Propane?
- 2 stage system?
- Running N2O and using OD normally aspirated.
- car falls on its face in 3rd on the spray....help!!!!!
- What is the best thing to use with nitrous to retard the timing when nitrous is on?
- HELP!!!!!!!!!!!!!!!!!!!!
- HELP!!! I need ideas on heating my bottle?????
- Who all is running a dry N20 kit?
- nitrous problems
- nitrous question
- Distribution blocks
- NOS 5176 QUESTIONS
- Help! What You guys Suggest?? Go with or w/out N20???
- Shark nozzle location in intake elbow?????
- Best plug to go with mt 100 shot???
- Is the LS1 OK with out a retard box?
- Autolite 103s OR 104s???
- Will LS6 injectors lock up under 90psi???
- Fuel Pressure Safety Switch installation question....
- License to sell nitrous?
- detonation? relay?
- ??? about nitrous
- Wet System as a Dry
- Anyone have a wiring diagram for this setup????
- nx install instruction plz
- ATTN: Musclecar Technologies and EVERYONE
- plz tell me how to read jets i have an nx wet system with 10 jets
- what pills should i put in my rpm activation switch
- CC 306 & Nitrous
- 250 Shot w/ Blower, stock internals (pics)
- BACKFIRES
- Stock fuel pump and nx wet kit????
- NOS Questions
- New used NX kit
- Post Pics of where your bottle is mounted...
- 35 hp an 50 hp jets wtb
- Anyone have pics of NX fogger nozzle install in elbow?
- Timing retard with MSD6AL
- Installed the Venom.
- Siphon Filling
- WOT switch install pics?????
- 100hp shot in 1st gear past 3k rpm?
- Here's what I have, what else to retard?
- 2 Step rev limiter w/ N20
- Anyone spraying with alcohol
- Spark Retard from stock computer
- st3500 and window switch?
- digital 6 settings
- Options besides NOS
- can stock crank/rods with forged pistons and 12:1 compression take a 150 shot?
- Which remote bottle opener should I get?
- post up your Switches plz
- Help Quickly Please!!
- Why so slow!!
- Best N2O Dry System
- How many shot N2O can I run If any at all?
- Converting NX EFI Kit to a Carb setup...questions!
- NX vs. TNT
- N2O for 4.3 V6 non-Vortec
- HOW DO I KEEP THE TORQUE CONVERTOR FROM LOCKING UP IN 3RD GEAR AT WIDE OPEN THROTTLE?
- good deal on NX kit?
- What's the best kit for "hidden" nitrous install?
- How many rwhp is a 255 intank pump good to?
- easiest cheap way to set timing on LT1
- window switch
- Pics of my N20 Set-Up - NX
- What is the difference between ignitions?
- need diff. plugs with nitrous
- Anyone use Edelbrock systems?
- Reasons not to go with a dry kit?
- Where is the best place to find an install page for a wet kit???
- ZEX Nitrous System
- anyone with a nx kit inside please
- Don't know much about nitrous
- confusion about timing on bottle?????
- NOS dry kit- .042 nitrous, .065 by-pass
- Computerized/Electronic Nitrous Control
- Pump Gas Nitrous
- Lots of N2O Questions
- Ktamez and others running digital 6
- Please post your times...
