NX intake, NXL DP system, 85mm TB
just got it in today. normally, this kit would have nozzles that go under the fuel injector. i got their LS intake that has the ports drilled into the intake for the nitrous and fuel.
the intake
here's a close up of where the nitrous lines will go to just like if you had a nozzle.
here's what it looks like inside the injector hole where the nitrous and fuel will come out
the underside of the intake has a 1/4" thick aluminum plate
inside the intake
the NXL direct port kit replaces the factory LS intake fuel rails. this way, it pulls fuel right off the rails
the fuel accumulator. this helps with the initial hit of the system.
the intake
inside the intake
Definitely a pricey setup, but it looks like it is going to turn out nice. Didn't you have a dual stage nozzle setup before? What are your goals with this new nitrous setup?
i still currently have the two stage n2o. haven't gotten the 100/150 shot working out past 1/8 mile. the 11.262 @ 122.78 ran was on a straight 200 shot coming on at 2700 rpms.
with the motor this setup is going on, it will be 9s capable. car itself won't be, but the motor will be. mid to low 10s, i'll be fine with.
CARiD
Jan 27, 2015 06:27 AM
Jul 4, 2005 05:00 PM
