Why does Nitrous cause detonation?
Old Oct 23, 2006 | 01:16 PM
HardcoreRM125's Avatar
I know it sounds stupid, and it probably is overly simple but ...
Seriously, what is it about spraying, that makes you have to pull timing? I know it can detonate, very violently, but the reason?
I was thinking about it today at work, I mean I know you should pull a degree ortwo for every 50 extra HP you spray, but the cooling effect of nitrous, I thought, would conteract have all the extra volume of air/fuuel to compress in the combustion chamber. Maybe it doesnt though
Apparently it helps some though as N20 cars can run a couple more degrees of timing than a FI car does. Or at least it seems like it.
Old Oct 23, 2006 | 01:57 PM
Ray@NitroDaves's Avatar
Re: Why does Nitrous cause detonation?
It is due to the increase in cylinder pressure....the more A/F mixture you force into the combustion chamber the higher the rick of detonation.
Old Oct 23, 2006 | 04:52 PM
srsnow's Avatar
The main reason you need to pull timing is that nitrous dramatically increases the burn rate of the fuel. You want to try and have everything burned by about 15-17 degrees after TDC. So as you add more and more nitrous the added oxygen being released speeds the burn rate up. Increased cylinder pressure can generate more heat which can lead to preignition which can cause detonation. So even if you could get enough octane to handle the amount of cylinder pressure you are generating you would still need to retard the timing to make sure that you aren't generating peak cylinder pressure too soon in the cycle.
Old Oct 23, 2006 | 08:12 PM
Nitro Dave's Avatar
Great answer....
Old Oct 23, 2006 | 10:11 PM
Thats exactly the kind of awnser I was looking for. Thanks I appriciate.
Old Oct 24, 2006 | 04:44 AM
oneslowz28's Avatar
verry good answer
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
95blkss
Sep 22, 2015 03:18 PM
nd4spd200
Aug 21, 2015 09:30 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
