View Full Version : N2O Tech
- Can I run 100 shot wet on 94 Octane w/out stock timing retard?
- throttle body plate
- looking for a wet kit,need suggestions...
- I know i'm going to get flamed for this...
- Re: LS1 auto and nitrous???? HELP!!
- How to wire it all together??
- How to Hook up nitrous?
- Nitrous Works Tunnel Mount
- Check out my mods> safe to Dyno?
- Nitrous Bottle Brackets
- MSD harness For Mallory 685..couple other ??
- spraying without tuning?
- anyone have the nitrous works plate kit for lt1
- Pics of switch panels
- No dyno tune.
- New add on !!!!
- Does nitrous go bad?
- Anybody used the "main line" system from NX?
- Bad spot for solenoids?
- Where to put fogger nozzle w/ Vortec intake elbow?
- Once you go Black...
- HSW nitrous
- Nitrous/Rear Gear Help
- What's causing my high r missing?
- ATTN. TNT users; What gains did you get on different shots?
- What kit to get
- New product @ HSW
- Compucar nitrous plate jetting questions
- NX Gauge mishap...(due to Summit..)
- How to seal my Fuel plumbing...
- Where did you mount your silenoids?
- Safe shot of nitrous?
- Nitrous Help!!
- nos question
- Wet vs Dry Kit??? Building my own kit
- Digital Dual Window Switch
- Plugs for the occasional spray??
- Accidentally Ordered a 125 shot...
- bottle opener / purge
- Window switches and retard boxes
- Where can I buy the SHO hose?
- Fogger Kit....What ignition upgrades?
- MSD Pills?
- Nitrous Help??
- leaking fuel solenoid...
- Spark knocking on a 50hp shot??
- problem with nitrous cutting on and off
- Could a 375rwhp n/a lt1 handle a 100 shot?
- Retarding Timing
- Plugs for Nitrous ???
- Ok, looking to step up to the plate...
- Window Switch setpoints
- Alternative to Mallory 685 box
- Plate vs Nozzle questions
- window switch ignorance
- Purge Line?
- dry nos pills
- nitrous
- :metal:anyone got a purge for sale?
- low buck bottle bracket
- thanks nitro dave
- N2O Cams....
- Wiring questions, bought used kit w/o diagram
- how do i set my timing?
- 10LB Nitrous Bottle Sale !!!
- mallory 685 - do I need to run an inline fuse for 12v power source?
- Project 1 Sweet Goat..
- nitro dave
- Carb kit conversion
- Fuel solenoid question.
- Does the length of line from bottle to gauge matter?
- Dry nos system
- Headers and Nitrous
- Wiring Questions
- How much is to much?
- Dual shark nozzle pic. request.
- How many ounces?
- Should i get nitrous?
- ordered a nitrous kit - anything else i need?
- What times with bolt ons and 100 shot
- Wiring Question.
- Nitrous ?
- Opinions on NOS Brand Kit
- fuel pump
- powdercoating bottle
- Pulling Time
- Plumbing Questions
- It's a long shot.......
- how much?
- spark plug gap
- Nitrous line question
- Nitrous Braket Mounting Plate
- can i run a 200 shot on stock motor?
- LT1, what new injectors
- Aluminum vs Brass
- Is there anywhere local to buy AN fittings? Ace, autozone etc?
- NX Jet settings GM nozzle wet kit
- jets?
- wot switch help
- Nitrous
- who blew up their motor on 150 wet shot also some ?s
- Nitrous question...
- LS1 and Jacob's nitrous mastermind
- what to do after?
- quick question, 50 shot need plugs?
- I'd appreciate a recomendation, thanks in advance
- best 100 shot package
- Fuel pressure ?'s with wet kit
- N20 questions
- Need Suggestions
- Autolite 104'
- Good wot switch and bracket
- will it hold
- Bottle pressure and nitrogen kits/setups
- Where do I mount this??
- Spark Plug Reference Chart
- What kit, 175-200 shot (wet)
- NOS Sniper kit
- Buying direct port kit, gonna need new noids, accessories...
- BMN or Nitrous Outlet Window Switch??
- Nitrous kit rarely works!
- NX Universal Bottle ?'s
- retarding the timing
- firends 383 lt1......how big of a shot
- timing dilema
- Check this out!!!!
- What kind of N2O should i go with?
- Shop Version LT1 Edit and Laptop 4 sale..
- 30 amp relay problem with NO2
- bottom end thoughts??
- Will this hold?
- Pictures
- help
- A new Product..
- Fuel Cell
- LTCC and Nitrous
- dual stage?
- njk tr-6
- So who Blew their Motor up on N20!
- is this too much spray?
- N20 and Street Driven
- stand alone fuel system
- NOS #17535 Fitting sucks
- pros/cons NO plate/NX-maf/tnt plate
- Fuel system changes needed and other questions
- New to Nitrous
- 2.73 car pulling a wheel
- Fuel Pressure Safety Switch
- Help a n2o noob please =)
- Question Jetting on Ls1 NX Wet Kit?
- Questions about Adding Nitrous
- February Nitrous Specials!!!
- alright to mount bottle upright like this?
- How to Hook up Horn Button for Nitrous (and still function normally)
- Nitro Dave>>
- lt1's tach line
- 100 shot
- Injectors for Dry Shot
- Fuel Regulator and Injectors
- My Zex nitrous wont work
- Why wont my nitrous work!!!
- TNT plate clearance issues??
- What Clutch with N20?
- Nitrous & Procharger
- Anyone using the TNT LT1 plate kit?
- Zex Wet, 100 shot, do I need timming retard?
- NX shark nozzle drill+tap size?
- Nos 5176???
- single nozzle setup on LT1 WS6 quick question
- Best way to splice wires.
- How often do solenoids need to be rebuilt/replaced?
- WOT switch
- Vortech Elbow and Dry Nitrous 125hp ZEX???
- Another sparkplug question.
- Nitrous Controller for sale
- Questions about Zex dry and aftermarker accessories...
- How much NOS to go from 11.7 to 10.5?
- Dynotune N2O kit - which solenoid is which?
- lt1 wet kit users, inside
- Wiring Mallory 685 with nitrous
- 383 high compression... nitrous?
- What is needed to piece a kit together?
- Best Kit....
- forged internals question
- Considering a 383 stroker build, looking for recommendations on nitrous engine
- Wiring
- 250-300 shot?
- Ignition box, and window switch?
- 150-175 NX shot
- This Really frustrates me....
- what kind of kit??
- nitro dave......
- Nitrous Heater News!!!
- Help with n20 kit?
- I had a problem..
- NEWBIE: What TPS switch to buy?
- Which Window Switch??
- Just bought a ZEX lt1 dry 75-125 shot, SUGGESTIONS?!
- Meth Injection?
- What would cause this? NOS BOOM!
- Nitro Dave
- Nitrous, your opinion..
- this kit complete?
- how engine safe is it?
- two stage setup
- Nitrous Filter Suggestions
- stand alone n2o enrichment AFPR?
- fuel pressure and wet kit...
- NITRO NEWBIE: Window switch w/ a TPS?
- ready to buy, still a little sketchy, HELP PLEASE
- nitrous><boost
- Nitrous express question
- NEWBIE: Set-up Question
- Sale on our new Progressive Controller, The Advantage
- Cool, New Products at Nitrous Outlet
- some n2o dyno testing
- buying a nitrous setup..is this all i need?
- How many of you spray with the stock 10-bolt
- nitrous plate
- will a 99 T/A zex wet kit work on 05 gto?
- Interchangable with LT1 & LS1?
- LS1 Questions
- nitrous jet compatibility
- Has anybody ever done this, and if no, why?
- Window switch for sale
- Tapping in Fuel??
- HELP rdy to buy but do not know wut
- How good are Zex kits?
- best wet kit lt1
- Why can't I see my purge?
- mph gain with a 100 shot?
- Bottle warmers
- stock parts
- dyno numbers!!!
- why do the dry lt1 kits not spray through the maf
- Spraing with a vortec elbow?
- How High With A -4an Supply Line?
- Retarding timing and which plugs to go with
- Spark Plug help
- Will a 250 shot work?
- Fittings??
- Best budget nitrous kit?
- How much?
- Victor JR 2 intake good for Nitrous
- do i need a racetronic harness?
- Nx Wet kit and msd window switch question
- need to run 11.60s........
- New Tech at Nitrous Outlet..
- How To Identify Solenoids
