- Help!!
- micro switch ?
- How did you wire your bottle heater?
- solenoid resistance
- nos placement
- Quick ? about wiring selinoids...please help!!!!
- stock intake elbow, or tri flow??
- Spark pulg question
- Ok, help the noob out please
- My car isnt running right any help?
- Want to run a seperate gas tank for N20??
- nitrous kit wiring help
- cc503"xe224/230 112lsa".....anybody run it with nitrous yet?
- Can a K&N FIPK work with NOS?
- Window switch for a 2000 LS1
- Think I am pushing my boundrys
- N20 on a third gen?
- Teach me about N2O.
- LT1 wet kit work on LS1?
- what plugs for nx 150 and iron heads?
- N20 cam choice for a 383?
- 95* Thermostats for NOS bottle heater...get in
- Electrical Connections
- Stock fuel pump and nitrous
- plastic instead of hard lines
- Ls1 nitrous guru's inside please
- couple of ???'s on a free dry kit
- Wet and Dry Kits
- direct port question
- Nitrous puge kit
- A Big problem with my NX Kit, PLEASE HELP.
- mild 454....is N2O wise?
- Need link to N20 button is stereo controls
- People that have used Compucar bag of Nitrous?
- LT4 set-up with N2O quetions??
- how much race gas and what octane !?
- NOS 5176 dry kit regulator shim question...
- Any guys have specs on a Nitrous cam thatll pass emissions?
- Times with Nitrous?
- Please educate me on the electrical part
- n2o nozzle and injector question
- Where to find these 2 items
- Purging nitrous into the intake?
- A few quick questions
- Checking/cleaning fuel solenoid
- where can I move my noids to without buying new lines?
- Stock Z28 M6 looking for suggestions
- Safe shot for a LS-6?
- Will a 15# tank fit in the spare tire well?
- Engage system and there is a delay for a split second...WHY? ANy suggestions?
- TB Plates - Spray Bar or Nozzles - Which is preferred?
- to much fuel???
- What plugs for Zex
- questions about autolite 104
- took plate out
- nx express kit wiring questions
- Nitrous Noid sticking open? HELP
- Direct Port ?s
- A4 and Nitrous ?
- Anybody know of a short header style plug, that's the same as TR-6's?
- Fuel pressure question
- n2o questions for a beginner
- Who runs the NX "white" filter?
- 12:1 compression +N2O
- mass air flow sensor
- Have N2O prices skyrocketed lately?!!
- Need pics and info on fuel cell
- Need Help Quick pt. 2!
- the new nx maximizer
- compucar ?
- MSD Window Switch
- Compucar wet kit
- Lets talk jet sizes...
- N2o plumbing help! quick!
- where to spray at in the 1/4 mile?
- average gains seen at the tire with NX & TNT
- how much shot is 91 octane gas good for??
- What is the best nitrous kit for an lt1??
- Remote bottle opener switch wiring...
- Purity of NOS?
- ForSale: 2LB NOS brand nitrous bottle
- Budget build up to handle a big shot of N2O
- Which is better, NX or Zex?
- NOS 5115 vs. 5176
- how dumb would it be to put a 100shot on an 90k mile lt1?
- anyone have an extra nx 20 jet and an msd 5700 pill laying around?
- window swtich
- questions about direct port
- Wiring in timing retard
- How to drive a M6 w/ 2 stages
- N2O TB Plate-type systems... interference issues?
- Nitrous Express NXL system delayed until the end of August
- what saftey items do you have?
- Best kit with blower
- whats the most someone has sprayed on lt1
- how much timing retard for 300 shot
- NX Kit: Regular or direct port.
- compucar nitrous system
- best nitrous kit for a LT1
- Special converter needs for N20?
- tuning
- race gas as replacement for timing retard?
- What am I missing?
- NItrous motor running N/A. No POWER!!
- fuel setup good enough for the N2O?
- Nitrous questions.
- Knock at same RPM point even w/ retard
- WOT switch doesn't fit BBK TB.
- need help selecting a couple of parts
- how much can u spray with a built motor
- Which ignition components needed to retard?
- purdge
- intake for a small shot
- Nitrous cam/NA cam
- what does the ZEX kit do for fuel?
- costs for a 100 shot
- Is this normal or does it indicate a leak?
- How hard is it to install a nitrous kit??
- Got to spray for the first time at the track today
- Small fuel cell in engine compartment
- jet sizes for nx kit
- A few random Wiring questions.
- N20 Kit NEED HELP
- What is pull timing???
- WOT switch question.
- What head gaskets are you guys using?
- FP safty switch
- pics of under hood setups?
- NGK TR6 and your gas mileage?
- leaving bottle in car?
- is window switch necessary for Msd 6al??
- Is purge valve necessary with nx wet kit??
- Jacobs Nitrous Mastermind install help
- advantages of race gas on the juice?
- autolite 103 or 104??
- Mustang 4.6 NOS kit on a LT1?
- Stupid gen X kit...
- Mph?
- Can someone help me wire up a dual stage system?
- Would I benefit from tricking the IAT when spraying?
- Progressive nitrous controllers
- Dry kit on 95 LT1??
- lost 50 hp on spray..WTF HELP
- Newbie Question
- how hard is n2o on the stock rearend
- Any difference between...
- Fuel Pump and Injectors
- NX question
- For those looking to get into nitrous cheaply...
- whats the most minimum clutch I can use with N20
- Nitrous Express
- What ET to expect with NOS...
- n2o will most likely to cause damage to.....
- bottle heater
- 150 NX kit on 383
- Nitrous People - FS: Start/Retard Control - PN 8982
- Locked out timing with nitrous
- Question about nitrous kit working on a 3rd gen?
- to spray or not to spray
- how much total?
- MSD Timing Box?
- cam suggestions for 85 TPI and 150 kit
- Zex kit fuel pump question
- Anyone running the new ZEX "wet" kit....
- NItrous question help
- Switch panel in ashtray help
- do i require some tuning for 75 nx wet shots??
- where to get jets for NX kit?
- does pcmfrless do good work for nitrous cams
- Death blow to N2O?
- Nitrous question
- nitrous backfire
- NXL kit? any scoop on this?
- NX bottle warmer question
- How many gallons of fuel are used?
- Anyone mount their bottle between the rear seats?
- Mounting Bottle in spare tire....
- NOS remote bottle opener wiring. Help please...
- Dual stage carbed set up
- How to mount NX switches in ashtray?
- My new Nitrous Install what do you think Pics Included
- my 1st bottle did not last very long (i'm pissed)
- What??? im confused
- how do i know how much nitrous i still have left??
- Can yall check my setup please
- This is just sick
- $40...wasted
- Custom Bottle Brackets.....
- Damn Compucar changed their design!
- nitrous on 01 ss a few ?s
- Bottle pressure
- shifting threw 75 shot
- The new Nitrous Express NXL system
- o.k. to spray through shifts??
- what should I get my stall set at with a 150 shot?
- need wiring help asap
- nos install price???is this right
- Question about fuel pumps?
- Digital nitrous pressure gauge coming soon
- Nitrous Filter
- getting ready
- Thought some of you may be interested...
- nitrous on a stock LT1
- what type of oil for nitrous use??
- Is there 2 versions of the NX remote bottle opener???
- which one better NX kit or TNT kit??
- What is the best setting for my mods???
- Some basic questions: Stock LT1 and N20.........
- nitrous info on my 98 z
- adjust pcm program for nitrous?
- Need help on zex LT-1 install
- Solenoid current draw?
- to Hawk, Timberwolf and everyone that replied to my threads
- is there anyway i check my solenoids??
- seriously, can you feel the diff. with 75 wet shots??
- 'Ghetto' Nitrous Install...?
- damn this bottle leak
- How many keep their N2O tanks visible? Poll
- How much does a Nitrous install usually cost??
- Bought a used compucar kit...have some questions.
- Do I need to upgrade my clutch before installing a nitrous kit?
- Colder Plugs / Fuel Pump
- wiring help w/ mallory window switch!
- Can nitrous line be used for fuel?
- Do police really look down on N2O?
- No2 Head gaskets??
- New Nitrous best,more to come.
- safest way to do nitrous
- Hobbs Switch?
- Plenum Spray Bar by Nitrous Works
- Looking for a bracket that holds two tanks
- the nitrous works whoas
- bottle heater questions.....
- You guys wanna see wwhat I got today!
- How to mount a WOT switch on my LT1?
- do you guys have pictures of your switches??
- how to launch on slicks with juice??
- Does this kit off of ebay have everything i need?
- purge work yesterday, but not today
- HELP... Lower ET with bigger jet???
- Dimentions of NX accessory switch panel.
- cam choice
- Question on NX remote bottle opener
- shutting off the bottle!!?
- anyone wished they'd gone supercharger/give reasons why or not
- Free remote bottle opener with any nitrous kit purchase!
- bottle warmer?`
- ZEX Kit is in!
- total advance
