can bottle be in cab with you?
Re: can bottle be in cab with you?
Yes, as long as you have the blowdown tube, and the system is installed in accord with the manufacturer's instructions. From NHRA Section 16, General Regulations, 1:6 FUEL / Nitrous Oxide:
..... All bottles must be securely mounted (may not use plastic brackets), stamped with minimum DOT-1800 pound rating, and identified as nitrous oxide. Nitrous oxide bottle(s) located in driver compartment must be equipped with a relief valve and vented outside of compartment. System must be commercially available and installed per manufacturer's recommendations. Commercially available, thermostatically controlled blanket-type warmer accepted. Any other external heating ofbottle(s) prohibited.
FMFRacing88
May 25, 2015 08:08 PM
Chrisbequick
Aug 4, 2002 12:45 AM
