rev limiter 1996 trans am
Old Oct 24, 2006 | 02:56 PM
96ws6medina's Avatar
I have searched and cannot find is the rev limiter in a 96 model trans am a4 set at 5800rpm or not?
thanks a bunch, im trying to figure out where to set my window switch for the nitrous i am about to install.
Old Oct 25, 2006 | 10:14 AM
i guess you guys are thinking "do a search".........trust me i did.
Old Oct 25, 2006 | 10:29 AM
jldak318's Avatar
5800 is correct. u can go to 6200 though. or atleast i did. some will say higher. but yes 58k is stock rev.
Old Oct 25, 2006 | 03:14 PM
HardcoreRM125's Avatar
But you cant do that on the spray, or your gonna blow your motor. It cuts fuel, not spark.
Old Oct 25, 2006 | 05:30 PM
thats exactly why i bought the mallory 685
Old Oct 25, 2006 | 05:31 PM
so from 2750 to 5700-5750 for my window switch?
Old Oct 25, 2006 | 09:54 PM
But that isnt going to do you any good. If you dont have the stock PCM reprogrammed, it still is going to cut fuel at 5800 RPM's. You have to set your 685's rev limiter a hair below the stock one, so say 5700-5800, and the window switch keep close to this, that way it doenst cut out on you too soon.
The Mallory will pull spark, not fuel. So if the PCM is pulling fuel at 5800, and your Mallory is pulling spark at 6000, your going to have serious issues if you hit the stock fuel restricted rev limiter.
Old Oct 25, 2006 | 09:55 PM
And let me know how it goes once you get this thing up and running right. Should be a neat project.
ANd where did you mount your 685?
oldschool
Feb 9, 2016 09:21 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Cam's maro
Mar 24, 2015 08:09 PM
armedtrigger
Feb 24, 2015 08:30 PM
siguy
Nov 27, 2014 10:07 AM
