Nitrous Outlet Christmas specials.
Merry Christmas everyone.
We have put together a few specials to help your dollar stretch alittle further through the holidays.
NOTE: All the Nitrous systems in the following group specials come with solenoids designed to flow 300hp, Nitrous solenoid has purge port design, The bottle valvewill flow 800 hp and has two accessory ports, quick release stainless steel bottle brackets, 20 ft main feed line,2 ft hoses from solenoids to nozzle, and all the needed hardware to complete your install.
(Wet systems have a 16 ft Main feed line)
Group 1.
(For you Corvette guys)
Dual nozzle dry system.
Nitrous pressure gauge
Fuel pressure safety switch
NHRA fitting
Blow down tube
860 Heated bottle bracket
Nitrous Outlet purge kit
Digital dual window switch (Has built in TPS and any gear lock out feature)
NGK TR6 Spark Plugs
Cost 775.00
Group 2
(For you GTO Guys)
GTO Halo system
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 799.99
Group 3
(For you 98-02 F-body guys)
F-Body Halo system
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 799.99
Group 4
(For the Guys running a cone style filter), (GTO & GM TRUCK)
Conical style filter system
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 755.00
Group 5
(One for everyone)
Universal single nozzle system
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST-835.00
10 GREAT STOCKING STUFFER IDEAS
Tell your loved one this is what you want in your stocking...
1. Nitrous Outlet Custom switch panels.
2. Nitrous Outlet Custom solenoid brackets
3. Nitrous Outlet Custom bottle mounts
4. Nitrous Outlet dual vent purge upgrade
5. Nitrous Outlet Custom billit micro switch
6. Nitrous Outlet T shirt
7. 860 Performance Spare tire area bracket
8. 860 V spray purge
9. 860 Hex to Wing adapter
10.Zex Colored purge Lights
DONT FORGET....
This month we are giving some lucky person 220.00 to spend where ever they would like.
See more info here. http://web.camaross.com/forums/showthread.php?t=487637
The specials count towards the drawing!!
You can call in your order toll free at 1-866-648-7637
Thank you & Merry Christmas.
Dave
Group 1.
NHRA fitting
Blow down tube
NGK TR6 Spark Plugs
Cost 775.00
Group 2
(For you GTO Guys)
GTO Halo system
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 799.99
Group 3
F-Body Halo system
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 799.99
Group 4
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST- 755.00
Group 5
(One for everyone)
NHRA filtting
Blow down tube
NGK TR6 Spark Plugs
COST-835.00
DONT FORGET....
Dave
RUENUF
Mar 13, 2016 03:37 PM
