View Full Version : N2O Tech
- Need some advice.. Heads/cam car with nitrous, stock bottom end
- anyone running sneaky pete?
- What's the best wet N2O kit....
- almost spraying time!
- N20 Pics
- venom vs. NX
- vid of me sprayin a high 12 sec bird
- Mods: can we make this a post it???
- thinkin my next mod might be n20....
- how do you install a bottle heater??
- how do you install a MSD window switch??
- Mounting bottle in Spare tire wheel well..
- ZEX Nitrous Kit Stealth Installation Info and Pics
- Alunmium or Iron heads w/ 150 shot?
- Questions. If y'all Don't mind.
- will a t rex inline pump be good enough?
- Electrical fuel pressure gauge and fittings.
- N20 for mostly stock LT1
- This Is why I will never go Wet Setup....
- Anyone ever done this?
- where can i buy a FPSS for NX wet shots
- How many runs on a bottle of NOS?
- a couple of questions if you guys don't mind!?!?!?
- hi guys
- Nitrous Express NXL kits ... here's the info
- Car "Coughs" on Nitrous...what's up?
- Drilling LS1 Holley intake for direct port..
- Air/Fuel ratio gauge ??'s
- Low Pressure DP Fogger ?'s
- NOSzle or NX Direct Port under the injectors...
- My new Nitrous bottle bracket
- recomend me some good plugs for a 150 shot on a LT1
- NX Wet - When hooking up the Fuel Solenoid, do you remove the shraeder valve?
- Importance of fuel pressure to jet size?
- just want to be able to purge air
- NOS Nozzles
- N2O Cam or just N/A Steet Cam
- nx wet kit 20920....help please
- Toluene or Race Fuel... does it tear up the solenoids?
- Direct Port Fogger? Anybody?
- TNT Jet questions--running very rich
- Need help
- How do I hook up my Timing Retard so it goes on with the Nitrous???
- Best LT-1 N2O cam?
- Hiding the Nitrous
- let me see your fuel system setups (fuel cell)
- have a few ?'s about a dual stage setup
- how much is a blowdown tube, usually cost??
- to spray or not to spray?
- confusion on the right jets???
- bottle heater thermostat
- Should I be considering a dual stage for a 175-200shot?
- i'm thinking about spraying my car
- Need help with bottle presure drop!
- How do I install & wire a purge kit?
- can I spray ahead of the air meter?
- fpss says 4-7psi did i order the wrong??
- Is nitrous SAFE???
- Purge and Bottle heater question
- How To:...wire up Zex kit to harlan window switch
- How Much Nitrous can I get away with?
- 89 nos
- will this bottle bracket fit my 10# nx kit bottle?
- Total Cost of Nitrous
- FPSS cause surging?????
- Low Fuel Pressure while Spraying?
- Holley airfoil&Trickflow elbow?tion
- Do n20 bottles need to be hydrotested?
- Are all TNT LT1 plates 58mm??? (will this disrupt airflow?)
- Where should I mount my nitrous bottle? Poll!
- anyone wanna trade a 5800 rpm msd pill for my 6000?
- Different ignition for N2O application?
- MSD Start/Retard box and timing issues?
- Keep fouling plugs??? Why?
- nos 5151
- Where to buy 10lbs. NX bottle?
- bottle on my motor
- Fuel PSI problems??? HELP
- Quick setup ? for my new nitrous kit
- Any where to buy wet kit with 2 or 5lb bottle?
- will running a wet kit clean the top end?
- ever had a hole appear in ur nitrous line out of NOWHERE?
- Help with nitrous set-up
- Nos on a stock LT1
- Nitrous/Fuel jets for custom wet nitrous kit?
- Quick ? for you guy's about type of fuel to use while sparying a 175 shot
- Nitrous sale!
- 8.5:1 compression 383, 250 shot, what plugs?
- purge install and things to buy.???
- Rookie now has a NOS System HELP!!!
- Vortech intake elbow ??????
- Impy head gaskets and 150 shot safe??
- shift points???
- anybody have a fuel Noid?
- Spraying out of the hole with a 4000 stall
- Best nitrous kit for ls1?
- dyno results and a little video
- LT1 TNT kit--Throttle Position????
- What pressure to set fpss at??
- Solenoids
- Iceman solenoid queston?
- do i really need a blowdown tube??
- Solenoid Questions
- Run juice with this setup?
- Dyno'd the car on the spray today
- Nitrous Switch Questions, Do I have the right ones?
- purge kit install
- anyone here of top gun systems??
- Recommend CR and rod length for a juiced 383
- Arming Switch question....
- Acquired Various NX parts and need to build LT1 system HELP!!
- tpi direct port pics?
- What plugs and wires to run???
- Nitrous newbie. Richard Krause Please Help
- Where does everyone with an LT1 Camaro mount switches?
- Will a 15lb NX bottle fit in the spare tire well?
- N20 NEWB questions...
- Dynotune purge and warmer...
- NX Purge Solenoid Fittings
- Gains spraying with ported heads?
- engine prep?
- Using N2O with LT4?
- Wet and Dry shots
- My Custom Switches, What do you think?
- 5176 NOS regulator question...
- extra nx noid? and can i use a compucar?
- Need Help Installing An In-Line Fuel Pump
- Relay wiring for 5176 NOS kit...
- 10lb Bottle
- Spraying off the line
- LT1 NOS 5176 + built motor trouble...
- LT1 TPS Wiring?
- why wont my car run good from a roll on N20?
- Where to get or how hard?
- Nos problem...please help
- noid problem!
- NOS Problems?!!!!!!
- MSD Timing Controller
- Custom fuel cell specs for wet nitrous kit
- Having trouble installing TNT LT1 kit
- Do I need a N20 converter?
- autolite 103's 104's?
- New to N2O with questions on cheapest 75 shot.
- Can I spray a 75 shot with stock ignition ?
- NOS remote opener with propane
- Pics on DP LT1 intake that is ACTUALLY ON the engine
- Where will my mph be after spray?
- spark plugs
- Cheapest Place to buy a TNT F-1 Kit???
- LT1 Nitrous gurus inside, need jetting size.
- FP dipping when the spray hits
- new to nos
- Problems with my nos inline pump. Help please
- How much spray can a 3.8L V6 camaro handle?
- Relays in the 5176 dry kit...
- If I put 300 jets on a stock car.....
- Direct port
- NOS Parts
- Quick question about how long you sustain pressure please...
- NX TPS activation switch?
- NX/NOS Kits
- Nitrious ?'s
- Pics of my trick flow elbow
- Compucar Blowdown?
- LT1 dry kit 75 and 100 Jets, what number?
- is it safe to run a bigger jet?
- what amp relay for bottle warmer?
- fpss?
- Separate fuel cell in the trunk?
- nitrous and a stock LT1
- not as bad for engine??
- I have a mystery jet... lol...
- Correct NX Jettings?!?!
- NOS fogger nozzle
- ZEX purge...
- mounting nitrous bottle in spare tire well
- Suggestions for which progressive controller
- On the quest for 10s tonight
- Where can I get the best price on a NX bottle opener.
- Is a Mallory comp140 a good N2O pump? Other??'s
- What else do I NEED?
- extending the blow down tube?
- Nitrous and removign MAF Screen/EGR Stem
- Grrr, what happened?
- 150 shot
- NX systems and parts
- Right jets for 150 shot?
- switching switches
- harlan window switch??
- Upgraded to NX shark nozzle and a 200 shot... 1 question
- NX Accessory switch panel + 97+ center console = the goodness!
- Heads+CAM+ DRY KIT, is it safe?
- First Time Bottle Fill and Hookup, help
- nx kit stage one + gen X 2 kit questions....
- I'd like to put the bottle back on my car, but I've got to figure out this problem.
- question about when to turn the nitrous on
- Powerdyne @ 6lbs. + 100shot?
- Question...
- Jet Size Question/ Running a #57 Nitrous & #38 Fuel, To Rich?
- NOS w/ forged botto emd
- Bottle heater or purge...
- nos dry kit! how much more?
- Need specific info on running purge lines through ram-air hood nostrils
- LT1 Dry NOS Kit Jetting Help
- What window/wot switch to get
- will a nos bottle work with nx kit/system??
- LT1 wet NOS kit question
- NOS 5177 kit??
- ANyone ever blow up there car w/ nitrous
- Burned pistons and duel plain manifold?
- Pics of where you have your solinoids mounted
- stock 4L60E with 100 shot...is it safe??
- How much HP have you LT1 guys got away with spraying dry N2O in front of the MAF?
- DIY hidden bottle bracket
- When good plugs go bad!
- New NX Kit, Track Results Not So Good, What's Up?
- Need help with NX 200 shot .
- N2O costs
- N2O on a LT1
- Vac. Hose come off FPR
- CC306 + N2O....am i crazy?
- T fittings for fuel and n2o
- Nitrous sale!
- NOS plate system
- Powder Coating your bottle
- edelbrock nitrous system, any good??
- blow down tube
- TNT or NX??
- Hard tech question: n2o vs NitrOx
- NX install on an F-Body...just finished the page.
- Where to get Nitrous Hose?
- Wet Spray threw MAF ??
- Dry vs. Wet?? and a couple other ?'s
- one more try and im taking it off !!!
- Can I run nitrous with my car without BOOM?
- Fuel Pump?
- What do I need?
- when is it time to do upgrade fuel pump??
- Few questions on Nitrous
- how to Prepare ls1 for N20
- Could a mustang N20 kit fit an LT1
- anyone leave their bottle open 24/7??
- going up to a 175-200 shot
- First nitrous run / jet sizes
- Separate fuel system ?'s...need help
- Where to buy -8AN hose?
- #5177 Dry Kit Nozzle Question
- NOS MPFI NOSZLE kit??
- irridium plugs?
- micro throttle switch mounting?
