Where to mount n20 lines
Old Jan 11, 2007 | 11:08 PM
69gto96z's Avatar
Where should I run my nitrous lines at? My bottle is mounted between my back seats. I was thinking about running em next to the fuel lines, or inside the car under the pass. side kick panel. Anyone else got any ideas, or wanna tell me how they did theirs?
Old Jan 11, 2007 | 11:30 PM
mrr23's Avatar
i ran mine down the passenger side door sill, up under the dash and out the rubber grommet that the wires from the PCM go through.
Old Jan 12, 2007 | 08:20 AM
69gto96z's Avatar
I have power wires for my amp there, will that matter? Also, if I go under one of the rear seats, will it hurt the line when someone sits there?
Old Jan 12, 2007 | 08:54 AM
jsetzer's Avatar
I run power and n20 through that hole. Just dont jerk anything through the hole. Power would ground to the body, an n20 line with a hole would just suck. But the fact that they are both there? No problems.
Old Jan 12, 2007 | 09:15 AM
69gto96z's Avatar
Awesome, anybody else got any recommendations? I am planning on doing this tomorrow morning.
Old Jan 12, 2007 | 11:37 AM
2000GTP's Avatar
I ran mine alongside the fuel lines as well.
Old Jan 12, 2007 | 12:13 PM
69gto96z's Avatar
So if the lines run under a rear seat, is there anyway someone sitting in the seat can pinch a line?
Old Jan 12, 2007 | 12:23 PM
2000GTP's Avatar
They are steel braided lines so it would probably take a pretty heavy person to pinch one.
Old Jan 12, 2007 | 12:42 PM
shuck's Avatar
I have mine ran beside the fuel lines under the car, I didn't want to run into any trouble with tech about having them near the driver inside the compartment.
Old Jan 12, 2007 | 01:21 PM
69gto96z's Avatar
Thats a good thing to know, I usually dont like people to ride behind me anyway.
Old Jan 20, 2007 | 02:44 PM
97rs4life's Avatar
there is a rubber grommet under each of the rear seats. I have my nitrous line going through the grommet on the drivers side and under the car to the engine bay. My pass side grommet I have my blow off tube going out of using some hose I found at the hardware
Old Jan 21, 2007 | 05:35 PM
There is no restriction regarding running N2O lines inside the passenger compartment. Personally, I prefer running mine under the floor, not through the compartment.
HectorM52
Jul 30, 2017 11:46 AM
HarleyZ28
Oct 5, 2015 06:23 AM
Jazsun
Dec 29, 2014 12:14 PM
T/A lt1
Oct 10, 2002 03:14 PM
