solenoid location
Old Jan 1, 2007 | 02:26 PM
69z-28's Avatar
solenoid location
i know you want them as close to the nozzle/plate as possible, but what about the fuel solenoid to the shrader valve? does that make any difference where it is located. im thinking about mounting the solenoids somewhere down below by the battery tray, and its a bit away from all the other underhood components like the FPSS and fuel pressure gauge sending unit. does the location have any effect on the performance of the system?
Old Jan 1, 2007 | 04:57 PM
Ray@NitroDaves's Avatar
You can mount them anywhere, as long as you keep the length of lines, from both solenoids to the nozzle,the same length.
Old Jan 1, 2007 | 06:00 PM
69z-28's Avatar
you mean keep them the same length? and also, i wont have any problems running the fuel solenoid far from the FPSS correct? and the purge solenoid will mount diretly to the nitrous noid yes? thanks
Old Jan 1, 2007 | 09:00 PM
yes...both lines from the solenoid to the nozzle need to be the same length....the distance betweent the FPSS and the fuel solenoid is irrevelant.
Correct, the purge mounts to the nitrous solenoid.
Old Jan 1, 2007 | 09:20 PM
69z-28's Avatar
great! muchos gracias amigo i love all these site sponsors you guys are on top of this stuff.
2QUIK6
Sep 17, 2016 02:31 PM
Queens94z28
Sep 20, 2015 08:45 PM
350350
14
Aug 11, 2015 12:03 PM
meissen
Aug 11, 2015 06:05 AM
Alibi
Aug 1, 2015 07:50 PM
