noszle system
Re: noszle system
this is the NOSzle kit
http://www.holley.com/08201NOS.asp
as close as you can get to a direct port with out drilling/tapping the intake
several different manufacturers make this style kit.
It places the nozzle under the fuel injector.
Re: noszle system
Re: noszle system
Originally Posted by bowtiepwr
>would there be a clearance issue with the length of the fuel injector and the "NOSzle" fuel/N2O ports and the fuel rail?
Re: noszle system
The shop that built my engine used the NOSzle system in their 7.0-second PRO5.0 Mustang. They tested to verify that the NOSzles did not interfere with the injector spray pattern. They also tried the NOS nylon tubing for the nitrous and found it worked surprisingly well. They did limit the NOSzles to nitrous only, but that's because they prefer dry systems.
14
Aug 11, 2015 12:03 PM
