View Full Version : N2O Tech
- Who's crazy on the GoGo Juice?
- how long does your bottle last you?
- Bottle mount for Spare tire?
- Looking for NOS y-fitting
- What are you running on your 305/350?
- nitrous problems with 95z
- not an N20 tech ? but funny...
- Spray with 12:1 CR, is it possible?
- Dual Walbro pumps - stock fuel lines
- polishing???
- Alternatives for bottle mounting besides trunk?
- Are all Fuel Pressure Safety Switches the same??
- Getting compucar Nitrous in a duffle bag need Help?
- TNT Nitrous kit Question
- NX plate?
- I have Forged Pistons but stock replacement rings; will it stand up to a shot?
- ZEX Nitrous System
- Bolt-Ons Only; 10.99's Possible w/ 150 shot??
- Best place to buy nitrous?
- What would happen if I ran platinum plugs with nitrous?
- Nx kit problems
- what pluggs for spray.
- WOT switch
- How can I run fuel line for nitous and still keep fp gauge?
- seperate Nitrous fuel system.
- Who's has the better Sq bore plate?
- Anyone spraying with over 128,000 on the clock?
- TNT fuel solenoid problems?
- 15# N2O bottle fit in 4th gen wheel well?
- Nx bottle opener switch ?
- NX direct port manifold for sale on ebay
- sprayed the 150 shot tonight....
- intercooler kits??
- question on "piecing" together a 2 stage system (long).....
- Purge Kit ?'s
- Car Bogs at 90-94mph on nitrous.....
- HELP with nitrous wiring on LT1
- 5176 fuel pump install questions...
- The quest for 10.99 on stock longblock may be over....
- remote opener
- Sparying with 2 fogger plates.
- Internally stock guys, what shot are you running?
- Walbro 255/90psi Fuel pump and 5176 dry kit..
- Nitrous with a cat?
- Nx kit vs Nos
- How to wire up nitrous with transbrake?
- How long does NX bottle heater take to warm bottle?
- The do not on nitrous
- NEED NOS info, pics what ever you got
- nx 150 shot, do i need a fuel system upgrade??
- bottle orientation?
- Progressice NOS COntrollers
- Not clear on how nitrous activates...
- Critique my N2O plan please
- What cam are you guys running with N2O?
- Whats the best way to set up a seperate fuel cell and pump for nitrous?
- How to "hide" spray kit?
- How Dangerous is N20?
- Who sells TNT products?
- New to nitrous, need your suggestions, thoughts facts etc.
- How often can you safely spray?
- What size jets to use for a 150 shot?
- dry guys inside please.
- Anyway to test the FPSS
- Car popping/sputtering on the juice; any ideas?
- when your digital 6 pulls out timing...
- fixing to install wet kit
- FS: Custom Dedicated Nitrous Fuel System
- Tried a 100 shot at the track!
- 4 Black spark plugs 4 clean plugs??
- whats all entailed in running a 100 shot??
- NOS bottle heater wiring ?'s
- Anyone have pictures of a TNT "wet" system on their LT1?
- What's the diff. between direct-port and non?
- octane, retard and power
- Diablo programmer or timing & MAF translator???
- NX and Lt4 clutch?opinions wanted.
- Dynoed with NX 100 shot today have a few ?'s
- NX opener on TNT bottle
- will the lt1 wet kit fit?
- Independent fuel system for n20?
- What engine mods to handle mild nitrous shot?
- bottle warmer??
- putting in 100 shot nitrous jets...should i put in 125 fuels jet??
- running juice on truck
- What is the ideal A/F ratio???
- What is a good cam to run with stock heads and the juice?
- An flaring Tool
- SES after install of NX kit
- Plate stlyle Nitrous system
- Direct port w/nitrous ONLY
- N20... How will it affect my Head/Cam plans...
- RWHP with LT's, CAI, Cutout, and 125shot???
- Can you run 100shot on heads/cam makin about 400rwhp??
- nitrous kits
- sprayed on the dyno tonight!
- Cost of N20?
- Wet vs. Dry?
- who has spray on there v6
- *HELP* how to install MSD rpm window switch
- What do u guys think about the XE 236 /242 cam on juince?
- Can I handle 75 shot?
- Gettin' cold up here...
- Need N20 install help NOW!
- Wiring up wot switch, what's are three prongs for, don't I only need two?
- Wondering about the effects of colder spark plugs
- question about window switch
- fuel line just screw into schrader valve?
- Fogger vs TB plate- which is better for me?
- TNT or NX
- I want to run a 200 shot!! How!??
- Leaky Fuel Solenoid.....
- 50 shot or so
- Leaky connection at fuel solenoid?
- specs?
- ZEX kit ?'s for heads cam car
- 4.8L heads and how much juice???
- I'm so confused..............
- is this a good/cheap NX kit?
- Window switch help?
- WAAAAYYY too much PSI!!
- What convertor to use with N2O?
- Where to find jet sizes?
- fuel line on the wet kit help please?
- Ignition systems?
- running nitrous
- shrader valve loose, spraying fuel everywhere....!!!
- Need numbers for nitrous jets!
- i am convinced
- Please help me figure out what to do for a fuel system!
- stock plugs ok for 75 shot?
- NX solenoid stuck open??
- Hey, what ever happened to...
- Is the Zex good for modded car?
- Buy Rev limiter or window switch first?
- Need help please.
- Q for anyone who has polished a nitrous bottle
- Help with Nx piranha nozzle
- ZEX bottle opener?
- jets
- Intake Is Back From The Coating Shop And Ready For Install
- What's the highest "safe" shot on this setup?
- Nitrous Express Direct port for sale
- anybody else experience this?
- NX users inside please!
- want to add nx, but...
- purge
- question about nx kit
- Newbie here in N20 Tech....
- n20 with FI
- Can the LT4 KM still be used with nitrous?
- pic or vids of 2nd gens purging.
- just posted this next door, but....
- 406 TPI + NX 150 shot... good idea?
- Pics Of My Direct Port Intake
- Spark plugs with wet shot?
- Need a new fuel set up
- $10 N20 Kit!!!
- stock motor, 150shot- fuel pump ?
- Can I interchange nitrous parts???
- NOS Noszle Systems...
- someone plz post up an jetting chart
- NX jets plz for an 125 shot
- Easy blowdown question
- spark plugs for wet kit?
- Pics for LT1 WOT location
- NOS jets
- zex kit
- where are you guys mounting bottles?
- anyone have the NX switch panel, fit in ashtray??
- where can i buy a NX nitours solenoid cheap??
- just got a NX kit, 50 shot, need tr6 and retard??
- How long for bottle to warm up?
- NX jetting for a 200 shot
- Opinion on TNT Force2 setup
- I need to write a paper in Class about Nitrous. Please help.
- Nitrous torque converter?
- last question about intake elbow
- Maximum shot with basic NX LT1 kit (no pills)
- Installation of NOS Dry Kit LS1
- cheapest place for 75 shot nos kit?
- NOS won't work!!!!!
- Aftermarket ignition box guys inside
- What is the diff. between the LT1&LS1 kits from NX?
- NX soleniod is rattling on the inside.
- FS: Complete nitrous system with bottle warmer and MSD
- What bottle warmer to go with? Do you pay for what you get?
- Blow down tube??
- Those with bottle mounted on hump between seats>>
- I need Pics of Hidden N2O systesm!!!!
- Aftermarket MAF okay with nitrous?
- xe 224/236 a few Qs
- NOS system for 2002 SS?
- 72# injectors for sale
- NX direct port forsale.
- biggest safe shot on 3.1 V6
- Spark Plug color!! 50-200 shot
- NX nozzle location?
- fuel safety switch
- What jets for 35shot (NX Base Kit)
- Should I spray without my MSD, or wait until I get it fixed
- N2O help please
- 4.10 gears & 125 shot too much for 315 tires?
- Where to buy Red Switch Covers
- Which One Is Colder? 103 or 104
- Fuel Pressure to low what gives???
- bottle in spare tire well?
- FS: Nitrous Express Fogger System on LT4 Intake
- Retard on 75 shot? My accel ignition doesn't have adjutable retard
- Anyone Know Anything about "Nitrous Works" systesm?
- NOS line
- New LT1 TNT Wet Kit W/ Electronics for sale
- TNTorNX
- what are needs to be done to install NOZ
- nitrous
- NOS Questions
- plug gapping w/ digital 6
- Tapping Rev limiter in auto?
- Who has the N.O.S plate kit for LT1 ? I need help !
- Just ordered nitrous what should I expect?
- wet shot, stock fuel rail, fuel pressure setting...?
- What do i need to upgrade to a 200 or 175 shot??
- Bottle Heater questions....
- Anybody here run nitrous works kit or am I the only one.
- How can I tell If i have 4an or 6an fittings
- hidden bottles?
- Vortech elbow?
- where are you guys putting your wot switch at??
- Jet Pattern NOS #8177
- *****nx kit and timing*****
- dry shot?
- Is anybody running a 255 Intank Pump and a 255 Inline Pump?
- Do I have a good enough fuel system to run 100 shot of nos??
- Still friggin pinging at 5k rpms....HELP!!??
- N20 Piston Coatings
- What is the best nitrous solenoid to use for a dry shot?
- NOS 5176 kit, what solenoid and nozzle does it use/
- What jet sizes for 100 shot? Kit doesn't say
- Another window switch question
- Fastest stock internal LT1 on the bottle
- What kind of fuel do I/should I, get for my wet kit.
- How much timing retard with a wet 175 shot?
- Got the nitrous works kit, now what accesories do I need
- How big a dry shot can my crappy 22lb injectors support.
- what fuel pump to get with a 150 shot?
- Thinking about going on the bottle!
- Purpose of having multiple bottles?
- Granatelli/Walbro same fuel pump???
- Vcn-1000
- Mallory Box users inside...
