May be a stupid question.
You should be fine, many people do it. I would recommend doing a cylinder leakdown test and make sure the motor is healthy before you start spraying. Also, if you do get a kit, I would set aside some extra money for the following: fuel pressure safety switch, better injectors(if using a dry kit), upgraded fuel pump (if using a wet kit), one step colder, non-platinum spark plugs (NGK TR-6 or Autolite 104s), a window switch, and a purge valve. Nitrous is always a hit or miss thing, but with all of those extras, you should be able to spray a 100 shot safely.
good answer......a lot better than the usual "pill it till you kill it"
Wet kits make A/F changes easier by changing the fuel jet, but bottle pressure becomes critical.
Dry kits don't spray fuel through the intake, but to make A/F changes you have to retune the car. Depending on the state of your fuel system you might need to upgrade the fuel injectors.
You have to decide which way is you are the most comfortable with. We offer both styles.
Ray
Like ray said you can really go either way on it. What mods do you have planned for the future? Depending on that answer one style might be a better choice then the other. We also have a few wet & dry kits that would work for you, let me know if you have any questions with them:
http://www.harrisspeedworks.com/shop/home.php?cat=248
Thanks,
Matt
Thanks,
Matt
NewsBot
Sep 14, 2015 09:20 AM
cmsmith
Aug 9, 2015 07:30 PM
Latronaxe
Jul 20, 2015 12:00 PM
Smokin 01 T/A
Aug 14, 2002 07:24 AM
